Old 05-09-2005, 11:46 AM   #1 (permalink)
mohit sharma's Avatar
Default am i in danger !
i have seen written in many online secrity generals tht use of antivirus software is must for online safety .
i m having athlon xp2.01 ghz. processor with 256 mb ram . it gets quite slow when sing any antiviruses .
so what i did is installed two windows xp on different partitions , get antivirus installed on one in least use and updated it , so tht i can scan my system from there offline.
now on most used windows i installed ' microsoft antispyware ' in active mode and zonealarm pro firewall in tighter program controlled mode .
am i really secure now ?
tell me !
mohit sharma is offline
Old 05-09-2005, 12:14 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Well, i better recommend u to have antis on both os coz of active items suspicions..
well otherwise u r very safe indeed !
be careful of what u download and avoid javascript when u can...
this is core security
also if u have zone 6 then no need of MS antispy coz tis good enough...
but for active scanning MS is good , zone scans on reboots
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-09-2005, 02:32 PM   #3 (permalink)
expertno.1's Avatar
the best would be to get a real time scanner like avast which has realtime http scanning and web shield
these protect my computers a lot
as far as you
you r safe though
expertno.1 is offline
Old 05-09-2005, 03:23 PM   #4 (permalink)
godsownman's Avatar
Is zone alarm 6 the free version good enough to protect the system.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 05-09-2005, 07:48 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
yep, probably the best firewall, there is !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
- by soumya
