Old 05-09-2005, 12:40 AM   #1 (permalink)
Default reg. external hardisk usage.
hi,
i have my pc running 24*7 and hav got a 160 GB external hardisk 2 days back. can i get it connected 24*7 as well? or it shud be used less frequently? how abt its stability? thk u.
/legolas
legolas is offline
Old 05-09-2005, 01:01 AM   #2 (permalink)
i think you should cuy down 1/6 of its time as it also depends on which company brand you are using
sam\'s
samleo109 is offline
Old 05-09-2005, 01:03 AM   #3 (permalink)
I think there should be no problem in using hdd 24*7 whether it is external or internal.
You acn definately go for it.
Only problem can arrise is of temperature(that too if it is heavily used)
Techmastro is offline
- by soumya
