Getting it done finally. But I'm only getting the
dibba spruced up. Will keep the monitor, optical drives and the UPS. KB, mouse and speakers are new neway.
Alright here goes:
Budget - 28K (not a lot more than that)
Apps - Gaming of coz, at low-to-med. res. Good enuf 4 me.
Priority - Long term. Like 5 years. (Second thoughts..maybe 3) Which is why I wanna maximise the mobo+procy investment since I'm not likely to upgrade those in the foreseeable future. GPU, RAM and basically everything else can be pushed down as low as is reasonable. O! And I'm also not likely to purchase a new cabby or HDD as a
replacement. However, I'ld obviously
add some space after a few months.
Config:
Procy : A-64 3200+ S-939 (which core?) - 9500 approx.
Mobo : ECS-KN1 Extreme - 8750
RAM : 256 MB DDR 400 - 1500 approx.
GPU : Gf 6200 PCI-X 128MB XFX or ASUS (which one?) - 3800 approx.
HDD : Hitachi HDS728080PLA380 80GB SATA2 (7200 rpm, 8MB buf) - 3000
Cabby+SMPS : 1500 approx.
NOTE:
1)
I'm NOT planning to OC in the near future.
2) RAM will be upped within a couple of months, UPS in a few more, GPU and monitor after about a year (or whenever it goes plonk. No I don't mind.).
So taking these factors into consideration, is this config balanced enuf? Any issues? And r there ne cheaper GPU alternatives (PCI-X ONLY)? Though I'm not likely to change my mind on the 6200..but still.
About the UPS, I currently have a 500VA
walla..working pretty OK. Had the battery replaced just a month back. Just a li'l noisy when the fluctuation mimick's
Amma Jaya's thoughts. But otherwise it's fine. Can I stick onto it? I wanna since I'm on a pretty tight budget.
Also, need suggestions on the RAM and cabby brands. I might want to squeeze the RAM a li'l bit.
