Old 04-09-2005, 03:37 AM   #1 (permalink)
Default help help help
GUYS i need help!!!!
god knows what is happening to my system is this a work of ghost maybe
coz so many problems does not appear simultaneously
1--- mY dVd drive is not working properly sometimes it reads the dVd sometimes it simply doesn't and god forbids the pirated cds. it jUst Dont't play them!!!
2.---- a error message pops upwhen i play a game or i start a new instaled software that says
"INSTRUCTION AT 0X00D400B2 REFRENCED MEMMORYAT 0X00000000. THE MEMORY COULD NOT BE "WRITTEN"" and sometimes it says could not read.
3--- im not able to get help from my friends so u r my last hope please help :roll:
BEHIND EVERY SUCCESSFUL STUDENT THERE IS ONE GIRL FRIEND
BUT WAT BOUT UNSUCCESSFUL STUDENTS??
LOTS OF GIRL FRIENDS
WINDWALKER is offline
Old 05-09-2005, 06:13 AM   #2 (permalink)
expertno.1's Avatar
1- reconnect the cnnections
2- ram probelm
expertno.1 is offline
Old 05-09-2005, 09:21 AM   #3 (permalink)
MVP in VC++
What is u r system config?..The second problem maybe due to Memory..try to remove u r RAM place it in other slot....
If u r in warranty period go for servicing of the DVD ROM Drive...
cvvikram is offline
Old 05-09-2005, 10:16 AM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Ur DVD ROM lens must be coverd with dust....so buy a CD/DVD Lens cleaner...Preferably...a Philips Lens cleaner (Rs.150/-)
For ur memory problem..plz check ur RAM..clean the RAM slot and the RAM module with a soft clean brush and try to insert the RAM modules into other slots aslo...
cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now
Old 06-09-2005, 11:29 AM   #5 (permalink)
Default Dvd Lens screwed dude!!
I had the same problem with my laptop dvd drive. The lens got screwed & would read very few cd's/dvd's. Try to clean the lens or else...
Febian
Life would be much easier if I had the source code.
Febians is offline
Old 06-09-2005, 01:27 PM   #6 (permalink)
...........Sure it seems to me that its a problem with your RAM. BTW are you using Hynix RAM?..If so then try reducing the RAM frequency from BIOS settings...It might work!
rkb2005 is offline
Old 08-09-2005, 06:24 PM   #7 (permalink)
expertno.1's Avatar
nah reduing the frequency will also have no any effect
its useless to do that
Old 13-09-2005, 12:47 PM   #8 (permalink)
It worked for me dude!!
I have a hynix RAM and the pc always used to crash..I reduced my RAM frequency to 133mhz now the pc is very stable although the performance degraded.
Every RAM comes with a specification about its preferable delay and latency for a given frequency..if that does not mach your pc may crash!
rkb2005 is offline
Old 14-09-2005, 08:40 PM   #9 (permalink)
Can u explain in detail how to change RAM frequency & wht was ur previous frequency.
Doesn\'t expecting the unexpected make the unexpected become
the expected?
(...) is offline
- by soumya
