Old 04-09-2005, 12:15 AM   #1 (permalink)
godsownman's Avatar
Default IE query
Can anybody please tell me how to reinstall Internet Explorer.
This is one task which just does not work on Firefox which requires IE .
So somebody please help me .
godsownman is offline
Old 04-09-2005, 12:33 AM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
If you are talking of IE 6 on Windows XP head straight to http://support.microsoft.com/default.aspx?kbid=318378
navjotjsingh is offline
Old 05-09-2005, 07:13 AM   #3 (permalink)
You can try IE7 Beta if you are using Genuine Windows... It can be downloaded from the Microsoft website
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 05-09-2005, 11:55 AM   #4 (permalink)
tuxfan's Avatar
You may not need to re-install. Just try a repair.
But NEVER TRY TO UNINSTALL IE :roll: It may screw up your system.
tuxfan is offline
Old 05-09-2005, 12:11 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
I think u can go to component contrls of control panel and install ie back again...
BTW how'd u uninstall ?
If u didnt uninstall jus go to run and type "iexplore" for IE to pop up...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-09-2005, 12:40 PM   #6 (permalink)
godsownman's Avatar
Thats precisely what I was wondering and so I asked . Anyway I shall try to repair it or else I will be forced to Format .
Thanks anyway
Old 05-09-2005, 02:41 PM   #7 (permalink)
I am Optimus Prime
It is still not available freely for download as you said. It can be downloaded only by users of MSDN.
Old 05-09-2005, 02:58 PM   #8 (permalink)
Commander in Chief
Adding to that, IE7 is a patch type installation and needs IE6 installed !
Harsh J
www.harshj.com
Old 05-09-2005, 03:09 PM   #9 (permalink)
godsownman's Avatar
How is IE 7 . Does it match Firefox or does firefox still rule .
Thanks for the advice but I will not be going in for IE 7 till it completely releases.
Anyway I'm mostly on Firefox, its just a few things that Firefix does'nt accept properly that requires me to go to IE.
Anyway thanks
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
Old 05-09-2005, 03:24 PM   #10 (permalink)
I am Optimus Prime
Don't go to IE 7. it crashes your system often and is not compatible with IMs. Also it does not stand up to Firefox. Firefox still rules. Stick to IE 6 SP1 on XP SP2 with all updates.
- by soumya
