Got a LG writer in an external drive case which I use through the USB port.Now whenever I want to write something the "choose recorder" drop down list always gives "Image recorder" and no other options.Tried in many machines but same prob.Using Nero.Plz help.
1)loose connections
2)driver not being detected i.e driver problem probably a hardware failure
3) try to use it with the com port
( if it supports the com feature)
4)os ? (mention pevious and next one)
