Hi,
Try this, open Internet Explorer, go to Tools Menu > Internet Options. Here click "Adavnced" tab and uncheck the option "Reuse windows for launching shortcuts" and click "Apply" and "OK".
Then check whether youcan open multiple IE windows.
If this does not solve the problems, then again in the Internet Options applet, click "Advanced" tab, and uncheck the option "Enable third party browser extensions" and click "Apply" and "OK". Close IE and reopen it, and check whehter you can open multiple windows.
http://swatrant.blogspot.com/
