Old 25-09-2004, 12:03 AM   #1 (permalink)
Default ntfs query
well we know that quick formatting a fat 32 partition means erasing the fat tables. but what does it mean to q format an ntfs partition? also what is the difference between full format and low level format(zero filling), if there is any.
geekgod is offline
Old 25-09-2004, 12:12 AM   #2 (permalink)
Quick format on an NTFS drive means re-initializing the MFT's (the equivalent of FATs)
A full format keeps the disks file system in consideration and formats the drive exactly according to the specifications of the file system. After a full format, the drive/partition is ready for use.
A low level format on the other hand doesnt take into consideration the file system and totally erases all traces of data (including the FAT/MFT, MBRs, etc). This makes the drive appear as if it were a freshly manufactured disk.
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 25-09-2004, 04:42 PM   #3 (permalink)
what is an mft? what is the file structure in an ntfs partition?
technomodel is offline
Old 25-09-2004, 08:00 PM   #4 (permalink)
busyanuj's Avatar
for information on NT file system, read:
http://www.ntsecrets.com/info/file_systems.htm
for info about MFT check this out:
http://www.ntfs.com/ntfs-mft.htm
how did I come to know?
simple, use Google
busyanuj is offline
- by soumya
