Old 03-09-2005, 01:27 PM   #1 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default SAMSUNG CD-RW Problems..
Hi guys well im having a SAMSUMG CD WRITER (1 year old) and the problem that im facing is that wenever i insert any kind of CD into the CD-RW drive,the tray jus comes out (with the CD in the tray) without auto running it..It fails to autorun or Detect any type of MEDIA,DATA,MUSIC or GAME CD.
ALso wen there is no CD in the drive..the empty Tray jus comes out without any reason (while the system is restarting or if im doin sum work) wich is not related to the CD-RW...
I know that SAMSUNG drives r not good drives..for a long running period..but since i wanna keep using this drive so plz suggest me a solution guys !
Does the CD-RW needs cleaning?? Plz suggest me wat kind of cleaner shud i use (any particular name for the cleaner) wich i shud ask for it in the market?? for this CD-RW ?? As i hv no idea abt CD-RW cleaners...
Help needed.....guys...
cheers n e-peace.....
ashu888ashu888 is online now
Old 04-09-2005, 12:43 AM   #2 (permalink)
samsung drives hav lots a problems..u should really exchange ur drive for another brand(pref sony or LG )..if u r still in warranty period. or u culd try cleaning ur lens with a " cleaning cd " ..pref philips ..but im not sure if that wuld solve ur problem..and there are no specific CDRW cleaners..as such..all such cds clean only the lens.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 04-09-2005, 10:51 PM   #3 (permalink)
Yup dude ur rite that Samsung drives jus suck...but neways... i got the Philips CD Lens Cleaner, popped the CD into my drive..started the cleaning process and the Drive is workin jus gr8 and smooth as butter... Thanx again for the advice man...
cheers n e-peace...
- by soumya
