Old 03-09-2005, 12:03 PM   #1 (permalink)
Default Problem with IE
I downloaded MSN Messenger 7.5 yesterday and also Messenger Plus 3.54.132
and after that some new links/folders have been added to the favorites menu and I am unable to remove them.
Help Needed Urgently
Think Once, Think Twice, Think Grace
Grace is offline
Old 03-09-2005, 12:48 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
what exactly error do u get on removin these entries ?
Also MSN Plus is a kinda spyware/adware and i recommend u better remove it.
u can use the manage bookmarks option to handle ur bookies.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 03-09-2005, 03:40 PM   #3 (permalink)
Un-installed Messenger Plus, but the problem still persists.
I am not getting error while removing the links/folders etc. Its just that deleting them or right clicking them is not possible.
please suggest a sw for managing bookmarks.
Grace is offline
Old 03-09-2005, 05:07 PM   #4 (permalink)
Problem solved
did some search and found the uninstall file of the spyware/malware installed from messenger plus
Grace is offline
Old 03-09-2005, 11:21 PM   #5 (permalink)
swatkat's Avatar
Messenger PLUS bundles Lop Spyware along with it. Anyway, you got rid of it
http://swatrant.blogspot.com/
swatkat is offline
Old 04-09-2005, 12:32 AM   #6 (permalink)
rajat22's Avatar
Scan your system with BPS SPYWARE & ADAWARE REMOVER. I was put into deep trouble with 'lop bar' and tried all anti spywares but BPS was able to remove it completely. Download BPS and scan your system.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 04-09-2005, 12:46 AM   #7 (permalink)
swatkat's Avatar
Actually, BPS is itself a rogue AntiSpyware software
To remove the bundled spyware of Msg Plus, the Lop uninstaller works good.
swatkat is offline
- by soumya
