Old 02-09-2005, 11:41 PM   #1 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default kickin a** of keyloggerz...
is there ne util(freeware) that's small in size, doesnt need ne installation & has high detction capabilties for keyloggerz & malware & spyware?
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 03-09-2005, 01:08 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
well i think y ! toolbar is good enough for keyloggers...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 03-09-2005, 02:28 PM   #3 (permalink)
sunnydiv
Posts: n/a
if the problem is serious
then get
1) mcrsft anitpsy
2) spybot sad
3) adaware
4) ZA firewall
5) antivirus
6) ....
Old 03-09-2005, 04:07 PM   #4 (permalink)
expertno.1's Avatar
he is aksing about anti keyloggers and what is y toolbar ?
spybot sad
its Spybot SnD
expertno.1 is offline
Old 03-09-2005, 05:54 PM   #5 (permalink)
Commander in Chief
well if u dont know then y ! tool bar comes with an antispyware protection for detecting all spies/loggers etc and is effective enough...
Harsh J
www.harshj.com
Old 03-09-2005, 07:46 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
visit www.download.com
download, install, update and use microsoft anti-spyware and spybot or adaware.
use them regularly, to kick axx of ur keyloggers !
if u want a variant, also use 'ewido security suite'. it has specialised detection capabalities.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 05-09-2005, 11:36 PM   #7 (permalink)
Back to l33ching :)
no no i dnt want nethin wich needs installation, coz i wana use it frm pen drive. i access net frm my colleg 2,
so need an app wich can b run on a system 2 chek for loggerz & spyware. sunnydiv, u hv mention ware wich needs 2 b installd,newayz thnx.
Old 05-09-2005, 11:44 PM   #8 (permalink)
swatkat's Avatar
Try MicroWorld AntiVirus ToolKit and/or McAfee Stinger
http://swatrant.blogspot.com/
swatkat is offline
Old 11-09-2005, 11:20 PM   #9 (permalink)
Back to l33ching :)
well i found out sumthin 2, calld "bazooka scanner", but it needs installation. but its small in size(abt 750k).
found it on download.com.
Old 13-09-2005, 12:06 AM   #10 (permalink)
swatkat's Avatar
Well, you could try Microworld AntiVirus ToolKit, an all-in-one scanner which needs no installation.
swatkat is offline
- by soumya
