Old 24-09-2004, 07:59 PM   #1 (permalink)
Default Spyware???????
Hi to all. I’m having two separate problems with spyware. I’m using Windows XP Professional with SP 2 installed; I use Zone alarm for firewall and AVG 7 as antivirus. A few of my cousins use my PC for net surfing. Recently I noticed an extra button on my IE toolbar – CrackSpider.net. When clicked it connects to that site. I’ve SpyBot 1.3 installed but it has failed to track it down. Is there any way of uninstalling it from my system manually?
Secondly, every time I run SpyBot to scan my system it detects certain DSO Exploits and some Download Accelerator ads. When I try to fix them it says all the problems could not be fixed and asks to schedule a scan at next startup; but nothing helps. The next time I run SpyBot, the same set of problems are back again. This keeps repeating every time I run SpyBot 1.3. I’ve tried using the older versions but they don’t detect those problems. I’m providing a copy of the log file of SpyBot below. Any idea how these can be fixed?
DSO Exploit: Data source object exploit (Registry change, nothing done)
HKEY_USERS\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3
HKEY_USERS\S-1-5-21-1844237615-1604221776-725345543-1003\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings\Zones\0\1004!=W=3
HKEY_USERS\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3
HKEY_USERS\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\Cur rentVersion\Internet Settings\Zones\0\1004!=W=3
Download Accelerator Plus ads: Default ad category (Registry change, nothing done)
HKEY_LOCAL_MACHINE\SOFTWARE\SpeedBit\Download Accelerator\ADSDefaultCategory=Default
Download Accelerator Plus ads: Ad category (Registry key, nothing done)
HKEY_LOCAL_MACHINE\SOFTWARE\SpeedBit\Download Accelerator\ADSUpdates
HKEY_LOCAL_MACHINE\SOFTWARE\SpeedBit\Download Accelerator\ADSProxy
HKEY_LOCAL_MACHINE\SOFTWARE\SpeedBit\Download Accelerator\ADSNoTrigger
HKEY_LOCAL_MACHINE\SOFTWARE\SpeedBit\Download Accelerator\ADSFileList
HKEY_LOCAL_MACHINE\SOFTWARE\SpeedBit\Download Accelerator\ADSCategory
HKEY_LOCAL_MACHINE\SOFTWARE\SpeedBit\Download Accelerator\ADSADS
indrajit is offline
Old 24-09-2004, 09:05 PM   #2 (permalink)
Jai Suresh
lywyre's Avatar
Spyware with SP2 installed. DAMN M$!
lywyre is offline
Old 24-09-2004, 09:21 PM   #3 (permalink)
The Photoshop Guy
cooljeba's Avatar
m8 most of those are from DAP and the remaining DSO expolit occurs due to the BUG in I.E for more informtation http://ask-leo.com/whats_a_dso_explo...rid_of_it.html
..:: Peace ::..
Jeba
cooljeba is offline
Old 24-09-2004, 10:29 PM   #4 (permalink)
mariner's Avatar
mate it looks like u clicked some button at the crackspider web site. thats the reason for that extra button on ur tool bar.
download ad aware se 1.05 from www.lavasoftusa.com.
download spywareblaster and spywareguard from www.javacoolsoftware.com
this is a lethal combination.
and also
change over to firefox or opera. u will forget IE 6.0
mariner is offline
Old 24-09-2004, 11:15 PM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Those are caused by a bug in Spybot Snd .. As long as the Zone Id =3 , you can ignore it ...
And if you run Download Accelerator, (its adware) you can ignore it from the list as it will download those ad files next time you go online .. So you can safely ignore them ..Its not spying ....
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 24-09-2004, 11:33 PM   #6 (permalink)
Other than the usual suite of SpywareBlaster, SpyBot, Ad-Aware, etc, you can try the following things
1) IE-Toolbar Manager:
This program should help you in removing any buttons in IE that you wish. You may even add your own buttons to the ie toolbar, or even customize the context menu
http://www.one.com.ua/ietool/download/ietoolm.exe
2) Autoruns
Get the autoruns program from sysinternals. This program has almost all the know startup locations of your comp, and displays a comprehensive list of all the startup programs. Just disable anything that looks suspicious
http://www.sysinternals.com/ntw2k/fr...autoruns.shtml
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
- by soumya
