Old 02-09-2005, 12:04 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Gif files ! ! !
how can u reduce file size of gif images ???
as jpeg files can b, with help of irfan view ...
ax3 is offline
Old 02-09-2005, 12:11 PM   #2 (permalink)
"Technologic"
Apollo's Avatar
I don't know of any tool whereby a gif can be reduced in size without actually having to manually resize all its frames.
One great use of words is to hide our thoughts.
Apollo is offline
Old 02-09-2005, 12:50 PM   #3 (permalink)
swatkat's Avatar
Open the image in IrfanView, and then go to Image Menu > Decrease Color Depth. Here choose "Custom" option, and enter the value (0 to 255) of color depth. And then click "OK" and resave the file.
You have to experiment with the color depth values such that there is no considerable loss in qulaity.
http://swatrant.blogspot.com/
swatkat is offline
Old 02-09-2005, 06:12 PM   #4 (permalink)
expertno.1's Avatar
and what about resizing the gif file ?
if i use irfan view to resize the gif file then the animation is gone
so how to slve this one ?
expertno.1 is offline
Old 03-09-2005, 12:55 PM   #5 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Why always Irfan View. I use Animation Shop. it works great to resize animation. If anybody is having problems post that file to me and I will resize it for you.
navjotjsingh is offline
Old 03-09-2005, 03:08 PM   #6 (permalink)
expertno.1's Avatar
what really is the animation shop ?
can u post a downlaod link for it >?
Old 03-09-2005, 04:29 PM   #7 (permalink)
I am Optimus Prime
Animation Shop 3 is a world class Animation Software from Jasc Software (now under Corel) - Creators of Paint Shop Pro 9.01
See it here: http://www.corel.com/servlet/Satelli...=1047024390003
Old 03-09-2005, 10:06 PM   #8 (permalink)
q3_abhi's Avatar
Try Ulead GIF animator.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 03-09-2005, 10:36 PM   #9 (permalink)
expertno.1's Avatar
thanks q3
i will try that also
Ulead GIF animator is free or shareware ?
Old 04-09-2005, 12:20 AM   #10 (permalink)
I am Optimus Prime
Ulead GIF Animator is shareware. Get it from www.ulead.com
Old 04-09-2005, 06:00 AM   #11 (permalink)
q3_abhi's Avatar
GIF animator is a good software for creating avatars. Many effects n utilities for enhancing ur avatar are available in GIF Animator.
q3_abhi is offline
Old 04-09-2005, 07:46 AM   #12 (permalink)
expertno.1's Avatar
now this is another Tales animator
Tales Animator is a rather unique tool to create custom cartoon animations in AVI format. It does not require any graphical talent to get started since it includes several of ready-to-use cartoon actors. All you need to do is write a screenplay, using a very easy to understand script language that uses a common English syntax which does not require any programming skills. The program comes with a sample that will get you started immediately, once you look at the documentation and the included sample, you will have no problems understanding the concept. Tales Animator lets you use custom background images (or included scenes) and the characters will speak their text aloud using MS Agent technology to convert your typed text to speech. The result can be saved as a project or rendered to AVI format or exported as animated GIF. This is a unique software with lots of potential. Check it out!
its freeware
http://www.snapfiles.com/php/downloa...=2880096&loc=1
Old 13-09-2005, 10:53 AM   #13 (permalink)
ax3
ax3's Avatar
Ulead GIF Animator is shareware ...
irfanview is freeware ... bt resizing in it just reduces the image size & u lose out THE ANIMATION ...
any solution for irfanview ???
... W H O T ...
ax3 is offline
- by soumya
