Old 02-09-2005, 10:25 AM   #1 (permalink)
doom_marine's Avatar
Default Chipset Fan Problem
I have an asus A8NE Motherboard .
The fan on the chipset stopped working and when i boot the system it warns me the fan is not functioning
What do i do?? HELP!!!!
AMD Athlon X2 4200+
2GB DDR 400 RAM
nVIDIA 7800GTX 512MB x 2 SLI
Creative X-Fi Fatal1ty Sound Card
400+160+74GB HDD SPACE
doom_marine is offline
Old 02-09-2005, 10:43 AM   #2 (permalink)
siriusb's Avatar
Take ur motherboard to the place where u bought it and they will replace it for free. This is a known problem in asus A8NE motherboard.
The comp will still work for as long as u use, but at a high temp which will shorten the life of the components.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 02-09-2005, 06:18 PM   #3 (permalink)
get it replaced...
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
- by soumya
