Old 02-09-2005, 06:55 AM   #1 (permalink)
Default Company Information
I want to know how the information is placed under the logo of Microsoft in the 'General' tab within 'System Properties'.
I have placed a snapshot (14 kb) of it:
http://img341.imageshack.us/img341/8858/property3il.jpg
I want to know the way of writing information as is written in the snapshot i.e. "Harword Computers"
Thank you very much in advance.
Naikosen
naikosen is offline
Old 02-09-2005, 12:06 PM   #2 (permalink)
"Technologic"
Apollo's Avatar
Here's what I think...
I don't know if one can write the info, that which you're asking for, without tampering with the OS's code. I think XP is protected under copyrights and tampering with it, without permission from MS, isn't encouraged.
Also, I have, in my college laboratory, seen logos of Acer Computers(and their contact details), below the XP logo in the 'System Properties' window. I have a theory that the retailers of XP, eg - Harwood Computers, Acer, etc, are those which might be requesting MS, officially, to endorse them and place their contact details on the 'System Properties' window, when they're ordering licensed copies of XP in a bulk quantity.
That is my view, based on a hunch for I haven't looked into the options if one can indeed easily place custom details on the System Properties window.
One great use of words is to hide our thoughts.
Apollo is offline
Old 02-09-2005, 12:33 PM   #3 (permalink)
aadipa's Avatar
http://support.microsoft.com/?id=218176
http://www.amset.info/netadmin/oeminfo.asp
these links should be enough for u.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 02-09-2005, 12:47 PM   #4 (permalink)
"Technologic"
Apollo's Avatar
LOL, see? You learn something new every every single day...
Thanks for the links! I should try it out too...
Apollo is offline
Old 03-09-2005, 02:25 PM   #5 (permalink)
Thank you very much "aadipa".
Problem resolved.
Naikosen
naikosen is offline
Old 03-09-2005, 03:32 PM   #6 (permalink)
siriusb's Avatar
If I am not mistaken, tuneup utilities also supports editing of these info.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 03-09-2005, 03:37 PM   #7 (permalink)
expertno.1's Avatar
is it really true ?
which tune up utility will do this ?
expertno.1 is offline
Old 03-09-2005, 04:12 PM   #8 (permalink)
siriusb's Avatar
The tuneup utilities 2004/2005. I don't know if this is what else it can change, but here's what I did to mine:
siriusb is offline
Old 03-09-2005, 07:02 PM   #9 (permalink)
Commander in Chief
QwertyManiac's Avatar
hahahaha
i think reshacker will help in this purpose...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 03-09-2005, 07:22 PM   #10 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its very simple.
U hv to put only OEMLOGO.BMP and OEMINFO.INI files into System32 folder ( Wndows XP ) or in System folder ( Windows 98 ).
Look at this screenshot:
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 03-09-2005, 07:27 PM   #11 (permalink)
Commander in Chief
wat shud be in the OEM ini file and also watz the restriction of the logo size ?
Harsh J
www.harshj.com
Old 03-09-2005, 07:36 PM   #12 (permalink)
Microsoft MVP
an overview of OEMINFO.INI file:
[Support Information]
Line1="--------------------------"
Line2="Mr. Vishal Gupta"
[General]
Manufacturer=Vishal Gupta
Model=U.P. India
Hope u'll get the answer...
And I think there is no size restriction for the LOGO...
Old 03-09-2005, 07:38 PM   #13 (permalink)
Commander in Chief
thnx v-gupta
well if no restrictions then what about 640x480
surely it wont fit...
Harsh J
www.harshj.com
Old 03-09-2005, 08:03 PM   #14 (permalink)
siriusb's Avatar
What he meant was that the input picture can be of ny size, but windows simply resizes the picture to that small window.
siriusb is offline
Old 03-09-2005, 08:21 PM   #15 (permalink)
Microsoft MVP
Yah!
Definitely...
Old 06-09-2005, 07:57 AM   #16 (permalink)
Originally Posted by Vishal Gupta
Its very simple.
Hi,
How did you put the picture in place of the Windows logo in system property?
Also the syntax in a batch file copy oemlogo.bmp "%systemroot%\system32" works in a good way in WindowsXP. But the same syntax does not copy the stuff in Windows98. How should I do to perform it?
Naikosen
naikosen is offline
Old 06-09-2005, 02:05 PM   #17 (permalink)
Microsoft MVP
Use Resource Hacker for this...
Old 06-09-2005, 08:36 PM   #18 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
I used Resorce Hacker for first image but the file sysdm.cpl returns to original immediately and image is removed. How to prevent it from changing.
navjotjsingh is offline
Old 06-09-2005, 08:50 PM   #19 (permalink)
Microsoft MVP
Its becauz of a system file protection service is running in XP, that immediately finds that a system file has been edited and replaces the current file with the default one.
The best way is to replace the edited file in both locations:
System32 folder as well as
System32\DLLCache folder.
There r many s/w available to stop this service as well.
U can also do it manually. U hv to edit the file sfc_os.dll (in system32 folder) and then some registry hacks...
Old 06-09-2005, 11:45 PM   #20 (permalink)
I am Optimus Prime
Please tell me name of such softwares. Your methid of replacing in 2 directories did not help. It still got replaced.
- by soumya
