Old 01-09-2005, 06:31 PM   #1 (permalink)
Default My PHP Script
I made a script called Hee-Haw Mailer.
It got listed on hotscripts.
Get it from :-
http://www.hotscripts.com/Detailed/51350.html
http://www.softwarearchives.com/deve...171&Class=2266
Its just for educational purposes.
Additions/Changes are welcome...
I visited thinkdigit after a month or so,i liked the new theme.
Thanks to Raaabo.
Lovedeep Wadhwa
cheetah is offline
Old 02-09-2005, 01:06 PM   #2 (permalink)
tuxfan's Avatar
What does the script actually do?
tuxfan is offline
Old 02-09-2005, 06:37 PM   #3 (permalink)
NikhilVerma's Avatar
This is what the author wrote
### Features ###
- Anonymous Mailing
- Mass mailing
- Single File
- Easy to use, plug and play.
One can use it for bad purposes...
NikhilVerma is offline
Old 07-09-2005, 04:11 PM   #4 (permalink)
Yes u can use it for bad purposes but as i have said alreay...its just for educational purposes and u can edit it to make anything...from simple form submit scripts to advanced newsletter scripts.
Additions are Welcome.
Lovedeep Wadhwa
cheetah is offline
Old 07-09-2005, 10:37 PM   #5 (permalink)
tuxfan's Avatar
Yeah bad purposes!! That is what I suspected and therefore I wanted to cross check.
@Nikhil: Of course, I can understand plain English. Can't I?
tuxfan is offline
Old 09-09-2005, 02:14 PM   #6 (permalink)
FooBar Guy
GNUrag's Avatar
Hmm,
Small suggestion:
if ($_POST['submit'] == 'Mail') // Form has been submitted.
has same effect as:
if ($_POST['submit'])
Actually the button controls eveluate to true if they have been clicked in the previous form, so there's no need to compare its VALUE.
http://web.gnuer.org
GNUrag is offline
Old 09-09-2005, 06:05 PM   #7 (permalink)
hehe.. I thought that you didn't read the text file...
But I still can't run it from my own PC using Apache...
How do I do that ?
Old 10-09-2005, 04:10 PM   #8 (permalink)
FooBar Guy
GNUrag's Avatar
You do have PHP and Pear libraries installed nikhil dont you? And apache configured to parse PHP files?
GNUrag is offline
Old 10-09-2005, 06:00 PM   #9 (permalink)
Well I dunno what Pear is..
But I have xampp installed on my system...
And I make and run php scripts on it...
Old 10-09-2005, 07:17 PM   #10 (permalink)
FooBar Guy
GNUrag's Avatar
Pear is the PHP package reporitory, somewhat in the lines of CPAN which is famous for Perl. http://pear.php.net/
There's nothing hi-fi in the script, why can't you run it? Do you get any kind of errors from it?
GNUrag is offline
Old 12-09-2005, 07:54 PM   #11 (permalink)
I get this error
Warning: mail() [function.mail]: SMTP server response: 553 We do not relay non-local mail, sorry. in C:\xampp\htdocs\site\hee.php on line 167
And also please tell me what am I supposed to fill in the fields "Sender's email address" And originating IP ??
Old 13-09-2005, 12:18 PM   #12 (permalink)
This is SMTP error. Run on php enabled server with smtp...
Lovedeep Wadhwa
cheetah is offline
Old 13-09-2005, 02:20 PM   #13 (permalink)
Version 2.0
Deep's Avatar
nice..pretty simple and decent..does the job
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 14-09-2005, 12:19 AM   #14 (permalink)
siriusb's Avatar
But it's not entirely anonymous, is it? I can see my IP (my smtp's) in the sent mail in gmail. I mean, u have to do an IP spoof to fool the receiving server. And it is not possible after some rfc was passed. Currently I am using anon remailers, but they restrict the time between mails. But I am having a list of remailers and using VB to use each remailer url in turn. But I don't have a lot of anon remailers and it takes a lot of time.
And, oh, I am not sending out spam. I am just experimenting with my own gmail IDs and yahoo IDs.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
- by soumya
