Old 01-09-2005, 01:23 PM   #1 (permalink)
bala4digit's Avatar
Default Dr.Divx help
i used the above demo to encode the normal avseq to divx but it gave video with late audio i.e the dialogues came out as audio after 2secs of video is it with demo or is there any option to correct it,pls help if there is with a step by step instructions.thanx
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
bala4digit is offline
Old 01-09-2005, 01:49 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
http://www.divx.com/divx/drdivx/guides/file.php
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-09-2005, 03:23 PM   #3 (permalink)
expertno.1's Avatar
yes u could also try virtual dub to correct the frame and audio mismatch
expertno.1 is offline
Old 01-09-2005, 08:01 PM   #4 (permalink)
bala4digit's Avatar
thanx q.m and exp#1 but i wanted step by step instructions if u have time pls gimme the steps of virtual dub audio config
- by Krow
