Well, you didnt mention the main things:
1) Make and model of your cdrom
2) Which OS you are running
Anyways, if you are using Windows XP, then you should face no problem regarding drivers. It could be that your CD drive's lens is dirty. Try cleaning your drive with a lens cleaner disk. If that doesnt work, reinstall your OS. Sometimes XP does encounter problems with cdrom drives disappearing. Reinstall XP and also apply Service Pack 2 (sp2) for XP.
Of course, if you are using Windows 98, then try updating your Windows 98, theres even an unofficial service pack for 98 se available on the net.
In the end it could plainly be that your CDROM drive has just become too old. Why dont you upgrade to a CD-Writer (costs ~1000-1500) or go for the Digit DVD drive/combo offer?
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
