30-08-2005, 11:08 AM
No pain....No gain
saving webpage
Earlier i use to save webpage by using the SAVE AS option in the file menu. Now when I use this option the webpage saves but I the pictures are not available(saved) as there is a blank space in place of pictures. I use opera 8.0.2. with zone alarm pro 6 and norton antivirus 2005 (all with default setting).
30-08-2005, 11:16 AM
Jai Suresh
Eariler, I guess, you should have used IE to save web pages. Now that you are using Opera, in the Save Dialog box, select "HTML file with images" from the "save as type" drop-down box. Now you will also be saving images.
Also make sure that u save it in a new folder, because opera saves all the images and script files in the same folder as the HTML file. (DAMN. I hate this).
30-08-2005, 12:26 PM
Another Brick in the Wall
what is this dude?
http://www.thinkdigit.com/forum/view...hlight=offline
Second thread on almost the same query, just changed some keywords?
30-08-2005, 12:47 PM
No pain....No gain
as i said earlier i used to view webpages by saving them but then came to know about offline browsing, but it didn't work for me. So went back to the old way but got this strange problem now. So u tell me if can help me or not. This is not the same topic as i have earlier posted......man I also have some sense.
30-08-2005, 12:51 PM
No pain....No gain
Thank you for ur reply but I save it as html file and always in a new folder but still the problem stays. Do I have to change any setting in zone alarm or norton antivirus as this problem arised after I had update them( I do update regularly)?
30-08-2005, 03:55 PM
1) you are using the operas default picture blocking "show no images" or "show cached only"
2) reinstall opera
3) disable zone alsarm and norton adn then try to save
4)post what happened now
30-08-2005, 04:27 PM
No pain....No gain
Thanks expertno.1
1) I use "Show images" for opera.
2) already done it twice.
3) diabled both but problem remains
4) still looking for a solution.
30-08-2005, 04:30 PM
No pain....No gain
and one more thing this problem is consistent with all the browser that I have.(IE. Opera, Firefox, Mozilla) actually installed other two to see if the problem still exists.
30-08-2005, 07:51 PM
1)it means any background softie is blocking the images
2)post a hijackthis log here
30-08-2005, 08:13 PM
Location: If I had a webcam u could have seen me, before your eyes.
try exiting zonealarm and then save... maybe this should fix it..
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
30-08-2005, 08:23 PM
he has already mentioned "diabled both but problem remains"
31-08-2005, 11:08 AM
No pain....No gain
experno.1 what is hijack this log.......... please specify steps if possible. and i use win98se.
Search this Thread |
