Old 23-09-2004, 07:28 PM   #1 (permalink)
adit_sen's Avatar
Default my computer acting strange
hey guyz,
i wuz tryin to change some icons in win xp and i really dunno wat i did, but now whenever i click my documents or my shared documents in my computer, a search pane opens up with the look in directed to 'my documents' or 'my shared folder depending on which i try to open. the same problem ocurs when i try the 'find target' in the properties of any shortcut. please help me resote things back to normal as it gets really irritating, having to go manually to c:->doc and sett->.......->my docs all the time
thankx
adi
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 28-09-2004, 12:05 AM   #2 (permalink)
Default Re: my computer acting strange
Adit,
Just right-click on the 'My Documents' icon on your desktop and let me know what are the options, which you can see and which one is in bold.
Souvik Sinha
SouvikSinha is offline
Old 28-09-2004, 03:57 PM   #3 (permalink)
adit_sen's Avatar
search is on bold...
adit_sen is offline
Old 28-09-2004, 05:03 PM   #4 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Looks like u changed th default action for folders to 'Search'. Open any folder, go to [Tools]>[Folder Options]>[File Types]. In that window, select file type as folder and click th advanced button. Set 'Open' as th default action.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
- by Krow
