Old 28-08-2005, 11:10 PM   #1 (permalink)
NikhilVerma's Avatar
Default [Scripting] PHP Troubles
Well I've been getting this problem for quite some time now.
This is a very simple PHP script found in the "Php5 and mySQL Bible"
<HTML>
<HEAD>
<TITLE>My first PHP program</TITLE>
</HEAD>
<BODY>
<?php
print(“Hello, cruel world
\n�);
phpinfo();
</BODY>
</HTML>
The problem is this when I try to run it. I get this error.
Parse error: syntax error, unexpected ',' in C:\xampp\htdocs\site\test.php on line 9
What could the error be?
I have made some php scripts earlier and I noticed this problem always occurs with the "echo" or "print" command.
Can you guys shed any light ?
I use XAMPP latest version.
If anyone wants I can post the "phpinfo();" output too...
Thanks in advance
NikhilVerma is offline
Old 29-08-2005, 12:14 AM   #2 (permalink)
Dear NikhilVerma,
The Double Quotes are wrong in your Script. Please use "" type double quotes. The modified script is below. Please copy it and run
<HTML>
<HEAD>
</HEAD>
<BODY>
<?php
print("Hello, cruel world
\n");
phpinfo();
</BODY>
</HTML>
alanpaladka is offline
Old 29-08-2005, 12:39 AM   #3 (permalink)
* Smacks himself on the forehead *
How could I not see that !!
Thanks for your reply alanpaladka ...
But I have one more question...
How can I use echo command to output quotes ??
The one that this command is supposed to to...
echo (" "I am an Idiot" ");
I know it's wrong, but what's the right way ?
Old 29-08-2005, 01:00 AM   #4 (permalink)
Version 2.0
Deep's Avatar
echo ("\"Yes, You are an Idiot :P\"");
that should do the job
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 29-08-2005, 07:44 AM   #5 (permalink)
hehe...
Thanks a lot Deep, that worked like a charm...
- by Krow
