Old 28-08-2005, 08:35 PM   #1 (permalink)
harish_21_10's Avatar
Default Fonts on the web
Hey guys,when i use some fancy font in a web page that is not installed with windows and host the file,i dont get the same font used that i used when viewed on different sys.Well i know it is bcoz the different sys doesnt have the same font installed but what i wanted to know is the solution to it...is there any way that others get to see the same font style that i used while building the page
NOBODY is PERFECT and i am NOBODY
harish_21_10 is offline
Old 29-08-2005, 12:24 AM   #2 (permalink)
String Phreak
mediator's Avatar
Yeah u can display the required font, I did it long time back but....
Actually u have to put the font style on the website and link the webpage to that font.
well if i remember correct style sheet was one of the option or aternately u cud do by <font> tag and adding the source!
mediator is offline
Old 29-08-2005, 01:28 PM   #3 (permalink)
I am not good in it,just a begginer so could u pls explain it in detaile...any example will be do
Old 29-08-2005, 02:06 PM   #4 (permalink)
desertwind's Avatar
One of my friend uses windows embedded font tools for the purpose. give a try that
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 29-08-2005, 03:35 PM   #5 (permalink)
expertno.1's Avatar
how to do that plz tell me
expertno.1 is offline
Old 29-08-2005, 09:19 PM   #6 (permalink)
well ant other way than windows embedded font tools?i am downloading this for now...some solution using html?hoe to give the source of font in html?
Old 30-08-2005, 01:11 PM   #7 (permalink)
I tried this software and works just fine,tnx desertwind...any other way to do this something related directly to HTML coding?
- by Krow
