| Forum |
#1 (permalink) |
P4 3 ghz with HT technology and 1mb L2 cache 512 mb ram 40/80 gb HDD Is it ok? Which graphics shud i buy?? and what will be the approx price of the machine...with optical drives etc...
~YOU LEARN FROM UR FAILURES , OTHERS LEARN FROM YOUR SUCCESS... |
#3 (permalink) |
512 MB ram cost you around 2600-4500 depending upon brand you go for.Also it depends upon type of ram(DDR, DDR2) & it frequency.
As for hdd price there is litle difference between price of 40 & 80 GB. you can go for either of samsung or seagate I purchased 80gb seagate for 2600/- selection of graphics card depends upon your budget.If you want to spend more than rs3500 than you must go for it otherwise onbard grphics will we fine. |
#4 (permalink) |
What? Where? How?
Hardware section is where ur gonna get some answers...
MODs please do the needful
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death. |
#5 (permalink) | |
The Hardware Labs
@BLITZ~KRIEG! will u be using this rig for gaming ? if not then u can go for onboard grafix. the prices of components u want are as follows, 3.0 GHZ P-4 (LGA-775) - around 8,000/- 256*2 (512 MB 400 MHZ) Kingston DDR - around 3000/- 80 GB Seagate SATA HDD - around 2900/- total - 14,000/- please tell us your purpose so we can provide a specific config in your budget. |
#6 (permalink) |
Hey guys Im planning to buy a new comp too, with the same budget. Can you tell me if onboard graphics have hardware T&L?And what is its VRAM?
Also which PCIex enabled motherboard is good. Blitz Krieg dude please tell me when you get your comp and the specs and total price. |
| Bookmarks |
| Display Modes | |
