Old 28-08-2005, 12:10 AM   #1 (permalink)
Default processor speed
hey all,
i recently bought a new pc. my processor is intel 3.2ghz (64 bit).mobo is gigabyte ga 81915g-duo,1 gb ddr2(533mhz).but my system properties shows that intel(r) pentium(r) cpu 3.20 Ghz ,3.69 Ghz. some benchmark software shows that there are multiple processor.i tried reistalling my windows.why these happens?any thing wrong...please tell me...i realy cant't understant.
vraja4u is offline
Old 28-08-2005, 03:18 AM   #2 (permalink)
please give the full specifcation also what price unhave paid if it is saying mutilple processor then most probaly u have bought a pentium d (dual core)in that case there is nothing wrong but right now the information u have provided is wayward and haphazard to say any thing
EAT DRINK AND SLEEP 3D
ASH18MARCH is offline
Old 28-08-2005, 07:39 AM   #3 (permalink)
I donot think it is dual core because for dual core the chipset would be 945 series....
I think he has got HT processor so the multiple processor is shown....
shivaranjan.b is offline
Old 28-08-2005, 10:03 AM   #4 (permalink)
Run CPU-Z.
It will report the correct clock speed.
drvarunmehta is offline
Old 28-08-2005, 11:14 AM   #5 (permalink)
run cpuz or check the processor box if you have it.. run intel processor identification utility available on intel's website... that will tell your processor speed, fsb, and cache memory and also if your processor is overclocked...
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 28-08-2005, 12:10 PM   #6 (permalink)
yes it can be hyper threding quiet possible
Old 28-08-2005, 07:45 PM   #7 (permalink)
hey i checked with the intel processor identification utility.it shows the correct configuration(3.2 Ghz).but why it is multiprocessor onsystem properties,whether my processor is overcloked.....does HT make this..
vraja4u is offline
Old 29-08-2005, 06:39 PM   #8 (permalink)
t3h g04t
teknoPhobia's Avatar
In winxp, a HT enabled proccy shows up as 2 proccys.
technologically challenged.
teknoPhobia is offline
