Old 27-08-2005, 11:21 PM   #1 (permalink)
thrash_metal's Avatar
Default Faking a File Size ???????????
I have a file which is abt 249mb . I want to know is there any way for me to fake the file size of the file to say about 700 - 750mb ?? The File is a video file (mpeg) i want to keep the same extension but increase the file size !!
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 28-08-2005, 12:41 AM   #2 (permalink)
sba
You can re-encode the file into higher bitrates?
sba is offline
Old 28-08-2005, 01:22 AM   #3 (permalink)
siriusb's Avatar
Default Re: Faking a File Size ???????????
Good question. U can try to reencode the avi to higher bitrates as suggested. It will definetly satisfy ur need. It will work for all media files.
I thought of suggesting u opening the file in binary mode and appending zero bytes. Something like how a download manager allocates files before downloading. And when u want to read back from the file, it'll just work. Else, just open it in binary again and delete all the trailing null bytes. This method will work for all files.
But most ppl, me included, would like to show a smaller file size than what is present. Is there a way to fake it like this?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 28-08-2005, 07:27 AM   #4 (permalink)
expertno.1's Avatar
the better would be to use virtualdub and instead of using compression methods leave it uncompressed or just use any other bogus compression method with high bitrates
expertno.1 is offline
Old 28-08-2005, 11:27 AM   #5 (permalink)
use virtualdub man...
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 28-08-2005, 11:40 AM   #6 (permalink)
expertno.1's Avatar
that i already mentioned
btw why dont u guys tell more what to do next ?
Old 28-08-2005, 03:53 PM   #7 (permalink)
siriusb's Avatar
expertno1: The thing u said was already suggested by sba. I also wanted to know faking the filesize as a lower one for all kinds of files.
siriusb is offline
Old 28-08-2005, 04:06 PM   #8 (permalink)
Yes method suggested by sbs & siriusb will work.
I have seen a dvd carrying only one movie (2hr) & having its size as 6.7 GB.
Techmastro is offline
Old 28-08-2005, 04:28 PM   #9 (permalink)
expertno.1's Avatar
i mentioned first about "not to compress it"
he mentioned about the "conversion of bitrates"
then i mentioned "or increase the bit rates"
then how i copied him ?
points are clear
and for more
u could use Power video converter
get it from here
http://www.freedownloadscenter.com/U...Converter.html
- by Krow
