27-08-2005, 06:31 PM
Jagah Kaam Hai!!!!!
my PCs D drive is 90% full. very often showing message of Low Disk space and giving option of cleaning up disk space. How to disable it?
27-08-2005, 06:39 PM
Commander in Chief
use tweak UI XP and go to Taskbar and Startmenu option(not ny submenu) and disable the check box for warn when low disk space...
Harsh J
www.harshj.com
27-08-2005, 06:43 PM
If u are comfortable with registry editing, follow this:
http://support.microsoft.com/default...b;en-us;285107
Else, u can use tweakxp or tuneup utilities (sharewares).
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
27-08-2005, 08:24 PM
the best would be to use tweak ui simply the best
27-08-2005, 09:38 PM
Microsoft MVP
Just copy paste the following code into notepad and save the file with any name, make sure extension should be REG, (like u can save the file using name "a.reg").
After it exit the notepad, double-click on this newly created file and when it asks "Are u sure......", click on YES and then OK.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoLowDiskSpaceChecks"=dword:00000001
PS: There should be some forum rules for using HINDI in the forum, like Topic name must be in ENGLISH, so that all members can understand its purpose without opening the topic.
27-08-2005, 11:44 PM
That's about the same info from the url i provided.
Also, i had pm ed the admin about hindi usage, but he replied that it wud be difficult to ask everyone to post in english. Ask him about enforcing topics atleast.
28-08-2005, 12:49 AM
Use tweak UI . Its damn simple.
\" I Do not like to repeat success , i like to move on to other things \"
28-08-2005, 07:36 AM
@linardi
one more thing tweakui will do it but since 90 % of your drivve is full i recommen you to clean it up using windows disk cleaner or system mechanic pro
28-08-2005, 11:29 AM
1. Click Start, click Run, type regedit, and then click OK.
2. Locate and then click the following key in the registry:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\Curre ntVersion\Policies\Explorer
3. On the Edit menu, point to New, and then click DWORD Value.
4. Type NoLowDiskSpaceChecks, and then press ENTER.
5. On the Edit menu, click Modify.
6. Type 1, and then click OK.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
29-08-2005, 03:38 PM
Keylogger
Plz let me know abt any keylogger software.....is there any freeware of this type? Thanx.
linardni
Search this Thread |
