Old 27-08-2005, 03:33 PM   #1 (permalink)
Default ram problem
my mobo is intel 845 with 128 mb ibm ram(168pin) now i want to upgrade it so i want to know wheather i can go for any brand like zion etc or i have to buy ibm ram only also tell me about price of sd ram 256 mb
dd1907 is offline
Old 27-08-2005, 05:36 PM   #2 (permalink)
ANy brand SD RAM (133 Mhz) will do. Cost of an additional 256 RAM will be Rs 1200-1300 .
cyrux is offline
Old 28-08-2005, 11:37 AM   #3 (permalink)
try upgrading to ddr... but if you dont wanna try sd any brand.. ibm is not a neccesity.... you understand...
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 28-08-2005, 12:18 PM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Hey does the 845 mobo supports the DDR RAMs ??? i really dont think so bro !!! (this is wat my h/w person told me).
Only the 865 intel mobos supports the DDR RAMs of frequencies 266,333 and 400 Mhz.....
Neways dd1907 i think u will hv to go in for a SD RAM coz the 845 mobo doesnt supports the DDR RAMs...(plz correct me guys/mods if im wrong..).U can go for HYNIX RAMs or TRANSCEND.....
cheers n e-peace.....
ashu888ashu888 is offline
Old 28-08-2005, 03:25 PM   #5 (permalink)
t3h g04t
teknoPhobia's Avatar
Ur "hardware person" is ignorant, all the late model 845's, 845 gvsr and afterwards, support DDR, so that has to be verified first. I'm not sure but 168 pin sounds like DDR to me
technologically challenged.
teknoPhobia is offline
Old 28-08-2005, 04:09 PM   #6 (permalink)
dIgItaL_BrAt's Avatar
boards based on the 845 chipset have DDR support,i myself am using 512 MB DDR333 (could'nt find DDR266) on an intel D845GLAD mbd.
@teknoPhobia
168 pin is SD RAM,184 pin is DDR RAM.
dIgItaL_BrAt is offline
Old 28-08-2005, 04:23 PM   #7 (permalink)
expertno.1's Avatar
ok now thats the case of SD ram so u need to upgrade
expertno.1 is offline
Old 28-08-2005, 07:41 PM   #8 (permalink)
I think the 845 gvsr uses SDRAM, When I was looking to upgrade I wanted to use the RAM from my P3 and this was one of the motherboards mentioned. But I went with DDR anyway so did not follow it up.
AlienTech is offline
