Old 27-08-2005, 03:14 PM   #1 (permalink)
Default "DivX Create Bundle 6" Problem
When I tried to convert a DVD movie to Divx using the trial version of "DivX Create Bundle 6" i am getting this error message
"DivX Converter Application has encountered a problem and needs to close"
How can I solve this...
ThnX in advance
anilthomas26 is offline
Old 29-08-2005, 01:00 AM   #2 (permalink)
in my view the best solution is to stop using divx create bundle...it's the orst encoding application presentky and has lots of bugs in it...even the divx 6 codec itself is not that stable...better to stick with divx 5.2...and for encoding use xvid or x264 codec with gordianknot/virtualdub...
Ankit is offline
Old 31-08-2005, 11:18 AM   #3 (permalink)
rajat22's Avatar
Try Dr.DivX but unregistered version will let you convert upto 50%
Install div X codec from Klite codec pack & is quite stable.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
