Old 27-08-2005, 01:53 PM   #1 (permalink)
String Phreak
mediator's Avatar
Default bits and bytes HELP PLZ!!!
I need a little cleaning up of my bits n bytes confusion!
Facts I know!
1. 1 byte (B) = 8 bits (b)
2 1KB = 1024 b
Now I want to know what is the maximum memory space or frame size a 32 bit system would take ?
I would appreciate a detail and clear explanantion! !
mediator is offline
Old 27-08-2005, 02:49 PM   #2 (permalink)
What? Where? How?
escape7's Avatar
same here, see a lot of posts related to 32 bit & 64 bit system etc...gove over my head.
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 27-08-2005, 03:28 PM   #3 (permalink)
Default Re: bits and bytes HELP PLZ!!!
Originally Posted by mediator
1KB = 1024 b
It is 1024 B. Not b.
32 bit memory indicates register size. A 32-bit register meant that 2^32 addresses, or 4 gigabytes of RAM memory.
Delta is offline
Old 27-08-2005, 04:55 PM   #4 (permalink)
64 bit can handle lots of RAM 2^64
cyrux is offline
Old 27-08-2005, 05:03 PM   #5 (permalink)
String Phreak
mediator's Avatar
2^32 addresses is fine!
And how do u calculate that 2^32 is 4 GB !
I mean 2^32 = 4294967296 addresses not some RAM size!
So how come 2^32 = 4 GB
mediator is offline
Old 27-08-2005, 07:06 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
the actual length of 4 gb is 4294967296
divide it by (1024)^3
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-08-2005, 11:04 PM   #7 (permalink)
String Phreak
mediator's Avatar
I know that! But u still havent figured out what iam trying to ask!
I mean 2^32 = 4294967296 addresses Ok. Lets round off this figure in giga term, So we have 2^32 = 4 giga addresses OK.
Now this is equal to 4 GB RAM if one address space = 1 Byte right.
So does that mean in 32 bit systems 1 address space = 1KB?? I believe not!
So how is 2^32 = 4GB RAM ???????
mediator is offline
Old 28-08-2005, 12:17 AM   #8 (permalink)
siriusb's Avatar
Watch me when I say, "A 32 bit machine can address upto 4GigaBytes of memory".
Modern computers are byte addressable machines, not bit or kbyte addressable.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 28-08-2005, 12:59 PM   #9 (permalink)
String Phreak
mediator's Avatar
I know 32 bit machine can address upto 4 GB memory.
But how do u actually CALCULATE DAT?????
mediator is offline
Old 28-08-2005, 04:28 PM   #10 (permalink)
siriusb's Avatar
Since no one else is answereing...
U gave the answer to it urself in the previous post: 2^32=4G addresses, with each address pointing to a memory location. Now that u also know that 1 location in memory is 1Byte, 4G addresses can address 4G Bytes. I hope this is what u asked of me.
siriusb is offline
Old 28-08-2005, 05:31 PM   #11 (permalink)
String Phreak
mediator's Avatar
Thanx siriusb Dats was the missing link in my mind!
Dat 1 location in memory is 1Byte.
mediator is offline
- by Krow
