Old 27-08-2005, 01:40 PM   #1 (permalink)
Default Convert a DVD movie to a 700 MB CD
Hi,
Please tell me the detailed steps to convert a DVD movie to a
700 MB CD(DivX)...with good quality..I have searched for this topic in this forum..but couldnt find the exact resuls..if anyone knew any link abt the DivX conversion please give me....
ThnX in advance
anilthomas26 is offline
Old 27-08-2005, 01:56 PM   #2 (permalink)
Dipen01's Avatar
Buddy Pls.. search using DVD to DivX or DVD Conversion.... and u will find lots of threads... already discussed...
take some efforts..
I love walking in Rain ,because no-one knows i am Crying
Dipen01 is offline
Old 27-08-2005, 03:54 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
First use DVD Decrypter to rip to your HDD.
DVD Decrypter is a free tool that allows you to decrypt and copy DVDs to your PC's hard disk.You can even use DVD Decrypter to erase / format your rewritable media!
http://www.dvddecrypter.com/index.php?act=download
The .avi's /.ogm's ripped from DVD Decrypter, produces the best result.
How to do:
1. Get DVD Decrypter (Freeware)
2. Get autoGk (Full pacakge) (Free)
http://www.autogk.me.uk/modules.php?name=Downloads
3. First use DVD Decrypter to rip the VOB file from your DVD and save them into a folder.
4. Now open up auto GK...and locate the directory where u've saved the .VOB files...and now u have the option to rip to whatever size...since u wanna rip to 1.37 GB (2 CDS) or 700mb ,tick that option....and then change the other settings if u wish..and hit RIP!!
Note the ripping speed depends on the PC speed and it's performance. Get autoGK only u have a faster computer.
drgrudge is offline
Old 27-08-2005, 08:18 PM   #4 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Default reply
rip the .VOB file from the DVD usind DVDripper.. and then use virtualdubMOD to convert them into .avi .. www.virtualdubmod.sourceforge.net
Alternatively, u can use Imtoo DVD Ripper [www.imtoo.com/dvd-ripper.html]
which gives u the options of converting a DVD to n no. of CDs as per ur req. but unfortunately is not free. On the other hand VirtualdubMOD is free but u hv to experiment a little to get ur desired compression.
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 01-09-2005, 01:33 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
hey drgrudge
the download does not occur
error is as:-
Forbidden
You don't have permission to access /AutoGordianKnot.1.96.Setup.exe on this server.
Apache/1.3.33 Server at len0x.shellpower.net Port 80
gary4gar is offline
Old 01-09-2005, 02:54 PM   #6 (permalink)
drgrudge's Avatar
You can google for alternate source to download!
Get it here:
http://www.free-codecs.com/AutoGK_download.htm
www.divx-digest.com/software/autogk.html
Google answer guide for the same topic:
http://www.answers.google.com/answer...view?id=464494
drgrudge is offline
