Old 27-08-2005, 06:51 AM   #1 (permalink)
q3_abhi's Avatar
Default How to use a UHARC compressor????
I have a this compressor. Can anyone tell m ehow to use it????
It is dos-based.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 27-08-2005, 10:40 PM   #2 (permalink)
Satissh S's Avatar
U can use WinUHA. It's the GUI version of UHARC comp
EDIT : U can download it from http://www.klaimsoft.com/winuha/
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 28-08-2005, 07:47 AM   #3 (permalink)
expertno.1's Avatar
get this
http://www.flexbeta.net/main/modules...on=show&id=107
learn the commands
http://www.klaimsoft.com/winuha/uharc04/UHARC.TXT
Size: 24 KB (23,717 bytes)
Transferred: 24 KB (23,717 bytes)
expertno.1 is offline
Old 28-08-2005, 11:14 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
thnx for the nfo palz finally compressed 16 mb to 156 bytes !
Harsh J
www.harshj.com
QwertyManiac is offline
Old 28-08-2005, 11:41 AM   #5 (permalink)
expertno.1's Avatar
is that possible ?
Old 28-08-2005, 02:33 PM   #6 (permalink)
Satissh S's Avatar
is that possible ?
May hav been 156 kb . , but that too is hard to believe. I know that it can compress 1800 mb to 1 CD (650 MB) .
Call it Emacs,
Old 28-08-2005, 02:37 PM   #7 (permalink)
Commander in Chief
u can compress text files like that buddies,
they r the easiest to do so...
winrar and ntfs too do this well....
http://www.thinkdigit.com/forum/viewtopic.php?t=27070
see the pic for a demo
Harsh J
www.harshj.com
Old 28-08-2005, 04:19 PM   #8 (permalink)
expertno.1's Avatar
u must have mentioned that its a text file
but even though 16 mb cannot be compressed into 156 bytes
never ever possible
Old 29-08-2005, 08:32 AM   #9 (permalink)
q3_abhi's Avatar
Is it that the Dos-based is more efficient than Windows based?????
q3_abhi is offline
- by Krow
