Old 26-08-2005, 05:28 PM   #1 (permalink)
In Deniel
raj14's Avatar
Default Random Error Messages HELP!
Hi all, recently i am getting these annoying messages, when i open applications like Yahoo Messenger or Mozilla Firefox, look at this screenshot, i was gussing this is due to a faulty ram module, am i right? please help me!
raj14 is offline
Old 26-08-2005, 05:37 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
no , even i get this , though only in VB and WINDVD,
the only option is reinstall OS, (i still hav to do)
repairin wont help...
i tried that too....
i think tis been discussed here and the author had reformatted and then got no problem....
urs is a sad case coz no FF...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 26-08-2005, 05:46 PM   #3 (permalink)
expertno.1's Avatar
well update it with autopatcher
expertno.1 is offline
Old 26-08-2005, 05:49 PM   #4 (permalink)
Commander in Chief
I tried that too,
no avail but...
ny other soln bfore i reformat tommorow ?
Harsh J
www.harshj.com
Old 26-08-2005, 06:02 PM   #5 (permalink)
In Deniel
raj14's Avatar
my System is well, updated, and i started getting these msgs recently, till now they show up if i try to send a smily on Yahoo! Messger or just surf on Firefox. i have to ram slots, my pc vendor installed cheap duplicate symtronics ram, 256MB DDr 266MHz, sboth were infact diffrent and gave a plethora of BSOD msgs, so i ought Original Hynix 512MB DDR 400MHz Ram, i instaleld in one slot, removing a ram stick adn leaving one on other slot, thus making total ram 640MB, i think the second 128MB stick is faulty and casuing the problem.what do you guys think?
raj14 is offline
Old 26-08-2005, 09:00 PM   #6 (permalink)
If you want to test your ram see here.
And why are you using your DDR 266 ram with the 400Mhz ram . This will make your DDR 400 ram run at 266Mhz. You test both your rams individually and individually in both the slots..... And let me know what happened....
Regards....
shivaranjan.b is offline
Old 26-08-2005, 09:34 PM   #7 (permalink)
Commander in Chief
nope...
my memtest is sucessful
no memory problems at all...
i have 2 oses , in the 2nd one it shows no error, so tis a OS error m8...
Harsh J
www.harshj.com
Old 26-08-2005, 10:25 PM   #8 (permalink)
Guys..
I don't remember exactly what that called.. but its memory miss-alocation may be its call MEMORY BLEEDING.
Its sorta Segmentation fault in linux ..
So reason can be
1.faulty programming ! (ie bad algo )
For first if you getting the error message only with one program then its the program .. else the hardware.
2. Bad hardware... ie. HD or RAM !
Try repairing and checking the HD and also RAM !
Reinstalling will help only when your HD is bad / had problem !
Well.. ..
That's my little piece of advice !
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
- by Krow
