Old 23-09-2004, 05:58 AM   #1 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Default XP SP2: SAFE MODE...
Nyone logged in to XPSP 2 SAFE MODE...
I did yesterday... and I was shocked... yuckkkkk!
Only 4-bit color display @ 320x resolution.... HUGE startmenu which was not even fit in my 17"... and all Graphic Options were disabled also... even it denied to go 800x600...
When it was XP SP1 one month ago Safe Mode used to be in 32 bit 800x600... and tht was cool....
Was this problem of the PC/PC's GFX I was using or it's happening everywhere...???
nybody checked XP SP2 Safe Mode recently ???
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 23-09-2004, 08:31 AM   #2 (permalink)
gxsaurav
Posts: n/a
Not a problem, even I m having it
This is due to the reason SP2 loads no drivers in Safe mode for VGA
Old 23-09-2004, 12:48 PM   #3 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
OMG
well thats the very reason we say SAFE MODE
only the basic hardware drivers will be loaded
usually safe mode is used when u need to configure something which usually desnt happen in the normal mode
say suppose there is a certain spyware in you pc its starting up during booting of ur OS
u go thru taskmanager to disable it or rather deactivate
sometimes it wont happen
so u cant delete the file
so we need to get into this safe mode trace the .exe(spyware file)
and delete it
another example some hardware drivers say ut GPU card drivers get corrupted so u cant boot into the normal mode
and reinstall the GPU card
its almost like in earlier days we had dos
hope you got it that why safe mode looks so bad
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 23-09-2004, 09:50 PM   #4 (permalink)
safe mode is used only in case of problems. noobdy uses it for everyday work. so it should'nt be much of a problem.
Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour, and it seems like a minute.
That\'s relativity - Albert Einstein
great_manish is offline
Old 24-09-2004, 01:03 AM   #5 (permalink)
safe mode is basically a problem solving mode...the problems which cant be solved or traced in regular mode, safe mode is used to trace them and then solve it...be it hardware conflict or software compatibilty issues...while in safe mode very limited and basic set of drivers are loaded...its not a mode for daily work...i guess, net wont connect while in safe mode...most networking drivers arent loaded too...so, just relax, its normal to have low resolution and all that in safe mode..you wont be working in safe mode normally anyways..
zenblue is offline
Old 24-09-2004, 01:11 AM   #6 (permalink)
Default Re: XP SP2: SAFE MODE...
are you a first time MS-Windows user??
ineo is offline
Old 24-09-2004, 02:11 AM   #7 (permalink)
lol!!! good one...
Slackware : The only GNU/Linux distribution developed on The KISS Principle!!!
Have you been kissed yet? : Get Slack
id10t is offline
Old 24-09-2004, 03:47 AM   #8 (permalink)
Web Entrepreneur
Lol.. well I'm not first time Win User... actually I was surprised when I saw that ugly 4-bit color display whether it used to be quite nice 32-bit when it was XP SP1 on the same PC.
Yeah I know Safe Mode means all multimedia disabled... but first time when I logged into XP SP2 Safe Mode... it was YUCCCKKKK !!!...
Old 25-09-2004, 11:02 PM   #9 (permalink)
alib_i's Avatar
my safe mode is in 16-bit colour display
and i changed the resolution into 1024*768
but its utterly slow in that resolution
intrestingly im not able to change it back
-Metallica
alib_i is offline
- by Krow
