Old 26-08-2005, 09:58 AM   #1 (permalink)
Default Power point
will somebody let me know how I can make my power point presentation to run only as a slide show without the slide sorter or editing view when I mail it to somebody.
cybertooth is offline
Old 26-08-2005, 11:41 AM   #2 (permalink)
Default ppt
save the file as <filename>.pps ( select powerpoint show as file type)...
~YOU LEARN FROM UR FAILURES , OTHERS LEARN FROM YOUR SUCCESS...
BLITZ~KRIEG! is offline
Old 26-08-2005, 11:46 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
yea thats easy...
in the save as menu u will find that option in the file type list box....
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-08-2005, 08:06 PM   #4 (permalink)
Default Another Power Point Problem
thanks a lot it was soooooo simple. Another problem with power point I am facing it that when i open a presentation and click on the slide show Icon a message window appears on the screen asking to configure the microphone for speech recognition. the problem is that this window does not close, neither does clicking on cancel command has any effect and the systrem hangs. i tried chechking the speech option in control panel but could not find any thing please help.
Old 27-08-2005, 08:46 PM   #5 (permalink)
expertno.1's Avatar
click on tools-speech
it will go
expertno.1 is offline
- by Krow
