Old 23-09-2004, 01:25 AM   #1 (permalink)
Default Help with SuSe 9.1
Has anybody tried Suse9.1. If yes then please tell me how to access gnome desktop. there is no option for gnome in the login menu. during installation i have also clicked gnome desktop but now after installation i can't find anyway to access gnome desktop.
fire is offline
Old 23-09-2004, 04:24 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
What login manager are you using ? If can't be GDM (gnome desktop manager) .... Its KDM i think.... Open KDE Control Center and go to login manager.... there you should be able to add more Desktop Managers.... for GNOME you have to enter gnome-session
http://web.gnuer.org
GNUrag is offline
Old 23-09-2004, 08:06 PM   #3 (permalink)
try the command "switchdesk GNOME" in works in redhat/fedora susi i have no idea
**** happens
pradeep_chauhan is offline
Old 25-09-2004, 11:10 PM   #4 (permalink)
i have checked the kde control center, there is option for gnome desktop manager n also i can't find which desktop manager im using coz there is nothing written like KDM or GDM.
fire is offline
Old 26-09-2004, 01:14 AM   #5 (permalink)
Hey im using SuSe 9.1 from a Live CD
i wanna know how to get my Hard Disks to mount as wen i start my system with SuSE it doesnt detect the drives on my comp
so wat to do ???
tried their help but unable to do it
can anyone help ???
talrejaharish is offline
Old 26-09-2004, 03:43 PM   #6 (permalink)
FooBar Guy
GNUrag's Avatar
Its a live CD, you cant do anything about it if your live CD is not mounting your partitions on startup... However i'm sure you are able to mount your partitions manually...
GNUrag is offline
Old 27-09-2004, 12:57 PM   #7 (permalink)
i heard tat i can mount it manually but i dont know how to do it !!!
can anyone post here how to mount the drives manually !!!
plz plz plz
its preventing me from using SuSE Linux
Old 27-09-2004, 05:41 PM   #8 (permalink)
FooBar Guy
GNUrag's Avatar
Mounting harddisk partitions manually
assuming that your C drive is FAT32, D drive is ntfs.
# mkdir /mnt/c
# mkdir /mnt/d
# mount -t vfat /dev/hda1 /mnt/c
# mount -t ntfs /dev/hda5 /mnt/d
On a live CD you can not write onto your /etc/fstab file, so you have to mount it manually everytime...
GNUrag is offline
- by Krow
