Old 26-08-2005, 12:10 AM   #1 (permalink)
hcp006sl's Avatar
Default SONY DVD RW DRU-810A - a review
  • Test Result 1:
    Disc Media used: DVD-ROM
    Quality of the Media:
    Type:CAV
    Seek Times
    Random 127 ms
    1/3 124 ms
    Full 177 ms
    CPU Usage
    1X 6 %
    2X 15 %
    4X 28 %
    8X 50 %
    Interface
    Burst Rate 23.93 MB/sec
    Spin Up/Down Times
    Spin Up Time 3.08 sec
    Spin Down Time 1.23 sec
    Load/Eject Times
    Load Time 1.36 sec
    Eject Time 2.09 sec
    Recognition Time 7.99 sec
  • Test Result 2:
    Disc Media used: Data CD
    Type: CAV
    Seek Times
    Random 101 ms
    1/3 117 ms
    Full 161 ms
    CPU Usage
    1X 1 %
    2X 1 %
    4X 3 %
    8X 6 %
    Interface
    Burst Rate 23.12 MB/sec
    Spin Up/Down Times
    Spin Up Time 2.21 sec
    Spin Down Time 3.34 sec
    Load/Eject Times
    Load Time 1.37 sec
    Eject Time 2.09 sec
    Recognition Time 6.88 sec
General Information
Operating System: Windows XP Home Edition (5.01.2600 Service Pack 2)
Drive: SONY DVD RW DRU-810A [IDE Pri-master 80 connector]
Firmware Version 1.0a
Software used: Nero CD-DVD Speed 4.04
System Info:
CPU : AMD Athlon 64 Processor 3000+ (S939)
Bus Speed : 200 MHz
Motherboard : MSI-RS480M2
Memory : 256 (x 2) MB 400 MHz DDR (DIMM0 & DIMM1)
Video : NVIDIA GeForce 6200 16x (256 MB)
HDD : Seagate 80 GB SATA
Orkut members are invited to join:
http://www.orkut.com/Community.aspx?cmm=28705185
hcp006sl is offline
Old 26-08-2005, 11:18 PM   #2 (permalink)
Good Work!!
Delta is offline
Old 27-08-2005, 12:41 AM   #3 (permalink)
First of all you need to use a FULL DISK. Every drive will do a good job for half the disk. Its the second half of the disk where jitter becomes a problem, as well as centrifugal forces comes into play that they fail. (Some drives are not good in the beginning but okay in the end because they over compensate for this). You also dont get to see what speed the drive maxes out at. If this is a true CAV then it barely hits 16x near the end. If its a PCAV then it hits 16X around 3-4 gig data area...
How much did it cost? What about noise? Tray problems, looks??
Thanks...
AlienTech is offline
Old 27-08-2005, 03:19 AM   #4 (permalink)
what this test means
is this good dvd writer or not
what about samsung dvd writer
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 27-08-2005, 06:20 PM   #5 (permalink)
Sony have introduced its tenth generation of DVD burners. The internal DRU-810A and external DRX-810UL models support the industry's fastest 8X DVD+R Double Layer (DL) recording speed, and can burn up to 8.5GB of video, data, music or images on compatible media in about fifteen minutes.
The 810 series of DVD burners also features 4X DVD-R DL, 16X DVD±R, 8X DVD+RW, 6X DVD-RW, 48X CD-R and 32X CD-RW recording.
Sony DRU-810A DVD/CD Rewritable Drive
ATAPI (EIDE) internal interface
DVD+R DL: 8X P-CAV (max.) writing
DVD-R DL: 4X CLV (max.) writing
DVD+R: 16X CAV (max.) writing
DVD+RW: 8X Z-CLV (max.) rewriting
DVD-R: 16X CAV (max.) writing
DVD-RW: 6X CLV (max.) rewriting
DVD-ROM reading (single layer): 16X CAV (max.)
DVD-ROM reading (dual layer): 12X CAV (max.)
CD-R: 48X CAV (max.) writing
CD-RW: 32X P-CAV (max.) rewriting
CD-ROM: 48X CAV (max) reading
Dimensions: 146 x 41.2 x 172.5 mm - excluding bezel (W x H x L)
Compatible with Microsoft® Windows® 2000 / Windows XP
Burst data transfer rate: 66.6 MB/s max. Ultra DMA66
Random access time: 135 ms (CD-ROM), 130 ms (DVD-ROM)
Buffer memory: 2 MB
Buffer under-run error protection technology: Sony Power-Burn™ conformed
Recording method (CD): Disc at Once, Track at Once, Session at Once, Packet Writing
(DVD): Random Access Write (DVD+RW/DVD-RW/CD-RW), Sequential Write (DVD+R/+R DL/+RW, DVD-R/-RW/CD-R/RW)
Compatible disc format: DVD-ROM, DVD-Video, DVD+R DL, DVD-R DL, DVD+RW, DVD+R, DVD-RW, DVD-R, CD-ROM, CD-DA, Video CD, Photo CD (multi-session), CD TEXT, CD Extra, and others
Available at Rashi Peripherals RS 4200! But some places sells it for 3900.
Sony DRU-810A is a rebadge BenQ DW1640. The best drive on the market. Guess the liteon rebadging does not work so good since most sony drives are liteon's but with better firmware.
Old 27-08-2005, 11:51 PM   #6 (permalink)
hcp006sl's Avatar
That's the M.R.P.
Market price Rs. 3650/-.
hcp006sl is offline
Old 28-08-2005, 12:10 AM   #7 (permalink)
hcp006sl's Avatar
Just compare this result with the following:
http://www.thinkdigit.com/forum/view...hlight=#230721
It's evident that no improvement was found in performance excepting for spin down time and recognition time. Then what's the benifit of shifting to BenQ?
hcp006sl is offline
Old 28-08-2005, 02:28 AM   #8 (permalink)
Well for one the burnt disks actually work.... For me, I dont look any further no matter how fast it burns it or how it does it. It seems a priority since I actually try to use the data I burnt onto DVD's/CD's...
Old 28-08-2005, 05:35 AM   #9 (permalink)
are 810 A dvd writer available in market
i think they will be available in 1 month
if available please tell where in bombay
thanks
also i have win 98
i cannot install win xp on desktop pc
can i use this drive or any one have 800 A dvd writer on win 98
thanks
AMIT AGARWAL
Old 28-08-2005, 07:08 PM   #10 (permalink)
hcp006sl's Avatar
It's available here in Kolkata.
Market Price: Rs. 3650/-.
hcp006sl is offline
Old 28-08-2005, 07:20 PM   #11 (permalink)
vignesh's Avatar
Cool review.My friend just bought one.
vignesh is offline
Old 28-08-2005, 07:21 PM   #12 (permalink)
vignesh's Avatar
vignesh is offline
Old 28-08-2005, 11:44 PM   #13 (permalink)
@ hcp006sl,
can u name the shop from where u can get the SONY 810 A ?
Windows XP Pro Service Pack 2 build=2600
Mobo- MSI PM8M-V
GenuineIntel Intel(R) Pentium(R) 4 CPU 2.40GHzRAM : Installed : 512 * 2 MB DDR RAM (TRANSCEND)
XFX FX5200 128 MB
medigit is offline
Old 29-08-2005, 12:44 AM   #14 (permalink)
hcp006sl's Avatar
Originally Posted by medigit
@ hcp006sl,
Supreme Technologies Ltd.
35, Chittaranjan Avenue, Kolkata - 12.
(Near Chandni Metro Station)
hcp006sl is offline
Old 29-08-2005, 02:48 AM   #15 (permalink)
I asked the rate when hcp006sl said it is available in the market
i asked rate in chembur
they said 4400 - 4500 Rs
why there is so much difference
when i asked the seller said we have to install and come to kalyan .also we have to come several times if drive has problem so taking transport charges in advanced
this way if drive has problem we will give it to the centre automatically where repairs are done u dont have to go
AMIT AGARWAL
Old 31-08-2005, 09:49 AM   #16 (permalink)
Nice Review buddy,i'm planning to get a drive in the next few days and have gone thru many threads here and have come down to two drives Liteon SOHW 1693S & Sony DRU-810A ur above comments have put me in a fix,if the sony drive is a rebadge of the benq drive shuld i go for the benq drive,i'm not quite aware of their quality,if some one has purchased it lemme know if its worth it or shud i go for a Sony or Liteon?
My Rig:-AMD Athlon64 2800+
ASUS K8N(nForce3 250 Chipset)
512Mb Transend PC3200
GeForceFX5200 256Mb
160Gb Seagate SATA
40Gb+20Gb Seagate PATA
BenQ DW1640 DVD-RW
del_x is offline
Old 31-08-2005, 11:25 PM   #17 (permalink)
The only 2 drives available right now and should be considered is the LG 4163B or later and the BenQ 1620 or up. I got the LG but if I could find +R disks I might have gone for the Benq/Sony. The 4163B has everything but the newier models have +R DL writing and such. But for RW/R/RAM media the speeds are the same. It is also faster than the BENQ by a few seconds because it starts writting at 7.8X while the BenQ starts off around 7.2X. Dont even think about liteon or samsung etc.
Old 31-08-2005, 11:42 PM   #18 (permalink)
yogi7272's Avatar
hi people ,
who says benq dw 1640 is not available in mumbai .. I just bought one at lamington road for 3.5 k - black ..
now forget abt all the other **** writers .. just go and get this one cos this is a really damn good stuff .. I can even give u the names of the shops if required ... now why people are thinking twice before going for benq? is it because of the benq brand is not well known in india? common this is a really really great stuff guys .. so get one today and forget abt the other brands .
yogi7272 is offline
Old 01-09-2005, 08:56 AM   #19 (permalink)
Thanx guys this has really helped,i'm going to Lamington rd today and might just purchase a Benq (:
GeForceFX5200 256Mb
160Gb Seagate SATA
BenQ DW1640 DVD-RW
del_x is offline
