Old 25-08-2005, 09:20 PM   #1 (permalink)
True Techie
nithinks's Avatar
Default Pinnacle PCTV pro users help me!
I just purchased pinnacle pc tv pro (Which was packed on september 04) I correctly installed it including its drivers and software.But i can only hear sound but there is no picture.
I had given country/region as India,and capture setting as PAL.
What may be the problem?
intel p4,3.1ghz
80GB SATA
512MB RAM
PCIe,HP mainboard,intel 915G Chipset
intel onboard graphics,128MB
Thank u in advance.
http://www.mytechyard.com/
nithinks is offline
Old 10-09-2005, 12:53 AM   #2 (permalink)
i m also using pc tv pro
and it is causing problems in 915 motherboard
u better download the new drivers from this link
ftp://ftp.pinnaclesys.de/driver/pc/p...P_SP2_WHQL.exe
download and update ur old drivers
this really solves mine also had the same problem but it works fine
thadhanihemant is offline
- by Krow
