Old 25-08-2005, 07:15 PM   #1 (permalink)
Default enabling the drive back... hw to?
hi,
i got a DVD writer 2 yesterday and had it in my friend's house for couple of days. he had by chance disabled the drive by going to properties and changing the option "use this drive (enable) option" to "disable". i then had it installed in my comp and nothing happens now. i hav connected the powersupply and datacable. but it doesnt get detected in windows. however, i am able to see the device in the bios screen. how can i enable this device back. pls help me.thk u
/legolas.
legolas is offline
Old 25-08-2005, 08:05 PM   #2 (permalink)
expertno.1's Avatar
go to Device manager there select your dvd drive and enable it from there
expertno.1 is offline
Old 25-08-2005, 08:09 PM   #3 (permalink)
are you sure it doenst gets detected ? . have u tried cheking the device in device manager ?
cyrux is offline
Old 25-08-2005, 08:49 PM   #4 (permalink)
expertno.1's Avatar
hmmm
try to reconnect it and then go to the bios screen and there refresh the detection
Old 26-08-2005, 05:23 PM   #5 (permalink)
Originally Posted by expertno.1
hmmm
it worked expertno1. thk u. btw, it was not detected in the windows before i did that.. or in device manager. thk u
/legolas
legolas is offline
Old 26-08-2005, 05:39 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Even if any device suddenly goes off, jus refresh and scan for new hrdware and it will pop again...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 26-08-2005, 05:56 PM   #7 (permalink)
expertno.1's Avatar
problem solved
now it wil work for windows also
- by Krow
