Old 25-08-2005, 04:20 PM   #1 (permalink)
club_pranay's Avatar
Default Rotating Picture... it it lossy?
i think i read somwhere that while previewing pictures in Xp if we rotate the picture there's a quality loss. is it true?
if yes, is there any way to either disable the rotate button or link it to the photo editing software?
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 25-08-2005, 04:51 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
I guess u read it in the warning dialog box of win XP when u try to rotate...
Well,
check this for some info...
http://www.impulseadventure.com/phot...-rotation.html
The pics quality reduces a wee bit if u save it that way, else if u dont save it...
No loss...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 25-08-2005, 08:24 PM   #3 (permalink)
expertno.1's Avatar
u can use photshop and then rotate...then no any loss
expertno.1 is offline
Old 26-08-2005, 08:49 AM   #4 (permalink)
Well,
No loss...
if the pic is not read-only, then you dont have to save it... it automaticaly gets saved.
Old 26-08-2005, 11:53 AM   #5 (permalink)
Commander in Chief
k, thnx for the nfo,
then make it read onlty and rotate...
as i said, it gets only a wee bit lossy....
also, isnt the thumbs.db file a temp storage for pics ?
then how the autosave ?
Harsh J
www.harshj.com
Old 26-08-2005, 12:23 PM   #6 (permalink)
siriusb's Avatar
d00d, thumbs.db is a thumbnail cache. Thumbs/thumbnails are those small preview pics displayed instead of the picture's icon, in case u missed it.
Also, the loss occurs because of recompression, so u can safely rotate bitmaps, methinks.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 26-08-2005, 01:52 PM   #7 (permalink)
Commander in Chief
but doesnt the module rotate the thumb alone ?
i mean the reso remains the same for me...
Harsh J
www.harshj.com
- by Krow
