Definitions of DMA on the Web:
Direct Memory Access/Addressing. A method of transferring data from one memory area to another without having to go through the central processing unit.
www.startech.com/glossary/glossary.cfm
direct memory access.
www.validationstation.com/glossary/glossaryd.htm
Document Management Alliance.
www.infonuovo.com/dma/dma1.0-7/glossary.htm
This term refers to the movement of data directly from memory to some other device, such as the disk drive, without first being loaded in the microprocessor.
http://www.homeandoffice.hp.com/hho/...0-225-121.html
Defense Mapping Agency
nplace.wvhtf.org/nplacenew/glossary.html
Designated Market Area. A Nielson term identifying groupings of mutually exclusive television marketing areas. Examples: Washington, DC, New York, Chicago, Los Angeles, etc. (Research Department, see: Market Book for details.)
advertising.washpost.com/special/displaycontact/glossary.jsp
(Direct Memory Access): the graphics adapter is not permitted to render directly from the AGP memory but it can take data from it as and when it needs to. This is currently the standard mode used as virtually all graphics cards have sufficient local memory to store the data it needs.
www.futuremark.com/community/hardwarevocabulary/
Direct Memory Access channels are similar to IRQs. DMA channels allow hardware devices (like sound cards or keyboards) to access the main memory without involving the CPU. This frees up CPU resources for other tasks. As with IRQs, it is vital that you do not double up devices on a single line. Plug and Play devices will take care of this for you.
www.tyan.com/support/html/glossary.html
A means of transferring data between host memory and a peripheral device without requiring the host processor to move the data itself. This reduces processor overhead for I/O operations and may reduce contention on the processor bus.
developer.apple.com/documentation/Darwin/Conceptual/KernelProgramming/Glossary/chapter_21_section_1.html
Direct Memory Access. A technology that lets system peripherals move data in and out of memory without using the CPU.
www.kingli.com/gloss.htm
Nielsen's term for geographical areas made up of exclusive counties based on which home market stations receive the predominant share of viewing. (See also ADI)
http://www.ignitingministry.org/adve...ediaterms.aspx
Is Direct Memory Access. A DMA channel permits specified types of data transfers between RAM and a device to bypass a microprocessor.
http://www.oasismanagement.com/frame...LOSSARY/d.html
Direct memory access (DMA) is a system of transferring data whereby samples are automatically stored in system memory while the processor does something else.
http://www.mathworks.com/access/help.../a3_gloss.html
A number identifying a channel whereby the device can pass data to memory without involving the CPU. Think of a DMA channel as a shortcut for a data moving to/from the device and memory.
http://www.build-your-own-cheap-comp...ter-terms.html
Direct Memory Access is an electronic pathway or direct channel on which a device can bypass the CPU and send data directly to memory. A DMA channel is often one of the resources assigned when configuring an expansion card or device such as a sound card.
www.pccomputernotes.com/pcterms/glossaryd.htm
A unique geographic area/media market defined by Nielsen Media research so that the entire US is assigned to one of some 210 DMAs. Nielsen states: "Designated Market Areas (DMA's) are used by Nielsen Media Research to identify TV stations whose broadcast signals reach a specific area and attract the most viewers. A DMA consists of all counties whose largest viewing share is given to stations of that same market area. Non-overlapping DMA's cover the entire continental United States, Hawaii and parts of Alaska." DMA definitions do not change for the Hispanic market.
http://www.hmweekly.com/data_center/...hglossary.html
direct memory access. DMA transfers data into memory at high speeds with no processor overhead.
http://www.cisco.com/en/US/products/...0803451e0.html
A term used by Nielsen Media Research to identify an exclusive geographic area of counties in which the home market television stations hold a dominance of total hours viewed. There are 210 DMA's in the US
www.nielsenmedia.com/glossary/terms/D/
Stands for Direct Memory Access. It is an efficient process of transferring data directly to and from main memory without involving the CPU.
www.cheap-hd.com/hd-terms.shtml
Designated Market Area, Used by the FCC, D* & E* to determine your television market for LIL service, and by V* to determine your local channel map.
www.satelliteguys.us/printthread.php
Accelerator used in conjunction with BPO catalyst. More effective than DEA.
www.fiberset.com/html/glossary/glos_d.htm
The direct transfer of information between a computer's memory and a device while the computer's CPU does something else.
www.visionneeds.com/glossary.htm
Direct Memory Access - A method of transferring data without having to go through the CPU. This allows for faster performance and also allows the CPU to spend more power on other things.
www.pantherproducts.co.uk/Jargon/d.shtml
Direct Memory Access. DMA is a method of transferring data from the disk into memory directly. In a CP/M system, the BDOS calls the BIOS entry point READ to read a sector from the disk into the currently selected DMA address. The DMA address must be the address of a 128-byte buffer in memory, either the default buffer at 0080H in page zero, or a user-assigned buffer in the TPA. Similarly, the BDOS calls the BIOS entry point WRITE to write the record at the current DMA address to the disk.
http://www.iso.port.ac.uk/~mike/inte...anual/axh.html
A method of fast data transfer between the peripherals and the computer memory. The transfer does not involve the CPU.
www.control.co.kr/dic/dic-d.htm
