Old 25-08-2005, 11:22 AM   #1 (permalink)
Default Re : Ethernet Adaptor
I have been told by my Broadband supplier(BSNL) that at my end I should be ready with Ethernet card. Can someone tell me how to carry out a physical check for it, if my mother board(ASUS P4GE-MX) has it or not ? And if I have to get it, which make is best to get and at what price ?
Thanks in advance
harmads is offline
Old 25-08-2005, 11:55 AM   #2 (permalink)
siriusb's Avatar
Check the back of the computer for a jack that looks like a phone jack but slightly larger. That is an rj-45 receptacle thingy. That confirms the presence of lan card (built-in or otherwise).
But ur mobo don't seem to have one. Buy a dlink lan card. That shud be gud enuf.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 25-08-2005, 12:00 PM   #3 (permalink)
club_pranay's Avatar
on the back side of your cabinet, look for a port like
this is an Ethernet port. it's slightly bigger than the ordinary telephone ports.
another way, go to system properties, then device manager.. look for an entry "network adapters".
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 25-08-2005, 12:31 PM   #4 (permalink)
Just Do It
Charley's Avatar
A 10/100 mbps card.....
Charley is offline
Old 25-08-2005, 05:55 PM   #5 (permalink)
a dlink card would cost you 450/-
Everyone is prone to fear.One who can dominate this fear is brave.
abhra_life is offline
Old 25-08-2005, 06:16 PM   #6 (permalink)
expertno.1's Avatar
that dlink card is supported for your mobo
u can get it
@abhra
i got that card in 400
expertno.1 is offline
Old 27-08-2005, 10:36 AM   #7 (permalink)
Thankyou all for your inputs..
1. I did find a Telephone type port at the back. There was no way to find out if it was a RJ-45
2. Then I did the the system check and found that Network Adaptors had a Fast Ethernet Adaptor
Thanks all
harmads is offline
- by Krow
