Old 25-08-2005, 07:52 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Dap 7 ! ! !
i use dap 7 ...
after any file is downloaded ... virus scanning pops up ...
in options of dap > download completion > scanner option > NO SCANNING is mention by default ...
i just want virus scanning 2 b done silently ... no popups ...
whot should i do ???
ax3 is offline
Old 25-08-2005, 11:21 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
which avs r u useing??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-08-2005, 01:41 PM   #3 (permalink)
tuxfan's Avatar
DAP has spyware! Don't use it. Rather use Free Download Manager. It came in a Digit CD/DVD some time back. I have recently started using it and its good
tuxfan is offline
Old 25-08-2005, 08:29 PM   #4 (permalink)
expertno.1's Avatar
are yaar DAP has no spyware
its the best
i am using it from last 2 years
see this
see the logo
http://www.speedbit.com/
and tell me ur antivirus i will tell u how to do this
expertno.1 is offline
Old 25-08-2005, 08:44 PM   #5 (permalink)
Dap has got a adware this is i found out when i scanned my pc through spybot search and destroy....
shivaranjan.b is offline
Old 25-08-2005, 08:49 PM   #6 (permalink)
Just Do It
Charley's Avatar
its the best
Lol, it does have the spyware in it.
Charley is offline
Old 25-08-2005, 09:09 PM   #7 (permalink)
Biplav's Avatar
no it doesnt.
and i think its been discussed all over .
dap has adware and not spyware.
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 25-08-2005, 09:15 PM   #8 (permalink)
Just Do It
Charley's Avatar
Originally Posted by Biplav
no it doesnt.
Lol, WHATEVER...
Do u have a soln for the problem....
Charley is offline
Old 25-08-2005, 09:39 PM   #9 (permalink)
Biplav's Avatar
i just downloaded a copy of dap 7.5 will download and tell u wat the problem is.
in the meanwhile: mr author
can u plz tell us ur antivirus software
and the exact version of dap.
Biplav is offline
Old 26-08-2005, 11:20 AM   #10 (permalink)
ax3
ax3's Avatar
i use norton antivirus 2004
... W H O T ...
ax3 is offline
Old 26-08-2005, 12:47 PM   #11 (permalink)
Just Do It
Charley's Avatar
i use dap 7
Charley is offline
Old 26-08-2005, 05:05 PM   #12 (permalink)
ax3
ax3's Avatar
hey koi to solution post karo ...
ppl using DAP, dont u get bored when these popups appear ...
& am using DAP 7.4 with NORTON ANTIVIRUS 2005 ...
... W H O T ...
ax3 is offline
Old 26-08-2005, 06:01 PM   #13 (permalink)
expertno.1's Avatar
ok now do this
tools-options-downlodcompletion-
tick the check for viruses
clcik on browse
nlow go to the nortaon antirus directory and select this file "navpw32.exe"
done
Old 26-08-2005, 08:38 PM   #14 (permalink)
Biplav's Avatar
well i think the popups are becaouse of ur antivirus and not dap
u mentioned that u want the scannings to be done without any popups.
well i am using nod32 with "silent mode" on.(its a feature of the av which notifies u of only important msgs)
and i dont get any popups.
so basically its a nav prob thats got nothing to do with dap
wat u can do is turn the scanning and av checking off. and scan the files downloaded manually
Biplav is offline
Old 26-08-2005, 08:57 PM   #15 (permalink)
expertno.1's Avatar
yeah i agree with biplav
u need silent mode from ur avs
Old 26-08-2005, 09:33 PM   #16 (permalink)
q3_abhi's Avatar
Free download manager is very good. It takes very less system loads, very small in size + its a freeware n very helpful. I use it regularly since DIGIT started providing it.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 26-08-2005, 09:36 PM   #17 (permalink)
Commander in Chief
QwertyManiac's Avatar
use flashget - tis the fastet....
Harsh J
www.harshj.com
QwertyManiac is offline
Old 26-08-2005, 09:47 PM   #18 (permalink)
well..
I have used many download managers.. even used freshd download,
Fresh download is good but its very limited.. it is not having ability to search for mirrors automatically + it don't let you specify mirror sites..
Say you are doing 200 mb download and after 150 mb the source site is down then ??? your 150 mb gone..
DAP is very efficient in searching for mirrors..
But I prefer flashget b'coz it can also search for mirrors but heck.. its useles.s. but I still prefer b'coz it let me spicify the mirrors at my own.. + its very clean.. And its blocks ie style of showing the progress is cool !
About DAP poping up window of antivirus.. better to turn it off and don't go for "unknown files" !
That's my little piece of sharing .........
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 26-08-2005, 09:50 PM   #19 (permalink)
Biplav's Avatar
c again we are coming to personal opinions.
i get speeds of 14-20 KBps on flashget and 34-42KBps on dap. at the same time downloading the same file from the same server.
so its on personal opinion actually as to wat is the fastest and the best.
: DAP is the most downloaded download manager software.
i suppose that speaks it all.
Biplav is offline
Old 26-08-2005, 10:41 PM   #20 (permalink)
hmm..
Frankly..
Flashget is somewhat stuff for more eperienced users.. b'coz at first the normal user will not even understand wher to begin !!
FYI .. I get better speeds of download on Flashget ! btw. basically its a general Idea but flashget sounds better..
btw. first download manager I used was DAP itself.. i hae used it from years.................
So still I m saying few days of experience of Flashget proves it better..
~Ricky
Ricky is offline
Old 26-08-2005, 11:39 PM   #21 (permalink)
Biplav's Avatar
well for that matter i used flashget.
just to knw it better used it for a month alongside dap.
for watever reasons other than that it consumes less memory than dap 7(not dap 5 as it takes more or less the same ram); i dont find flashget better than dap.
Biplav is offline
Old 27-08-2005, 07:17 AM   #22 (permalink)
expertno.1's Avatar
dap better than any other downlaod manager
tell me how lashget beter than dap ?
Old 27-08-2005, 01:15 PM   #23 (permalink)
nipun_the_gr8
Posts: n/a
I have been using DAP for 2 yrs and i never had any problems with it.
DAP ROCKS !!
Old 27-08-2005, 01:19 PM   #24 (permalink)
Just Do It
Charley's Avatar
Mods please check this thread , the topic is now diverted widely from the topic.
Seems really unreasonsable.
Charley is offline
Old 27-08-2005, 02:05 PM   #25 (permalink)
expertno.1's Avatar
what? ahcacko
the problem is solved now
thats antivurs problem and not daps problem
topic should be locked
Old 28-08-2005, 03:24 AM   #26 (permalink)
I wish if I could use =)) over here..
Anyways.. The one fits you is the best..
Antivirus Vs DAP ?
or Vs... Flashget.. ?
I m just laughing !
~Ricky
Ricky is offline
Old 28-08-2005, 07:22 AM   #27 (permalink)
expertno.1's Avatar
Antivirus Vs DAP ?
I m just laughing !
are yaar it depends on the antivirus you are using and not the dap
coz he asked to remove the pipup
such as i use avats and the popup comes
but in silent mode o popups comes
so chnage your antivirus settings
Old 28-08-2005, 07:37 AM   #28 (permalink)
vignesh's Avatar
I have been using free download manager and fresh download.Both are really good.
vignesh is offline
Old 28-08-2005, 12:44 PM   #29 (permalink)
Biplav's Avatar
y the he** are we diverting ?
there are enough threads to suggest which download mgr to use.
lets just keep ourselves to solving the problem instead of suggesting an alernative dwld mgr.
Biplav is offline
Old 28-08-2005, 01:11 PM   #30 (permalink)
expertno.1's Avatar
and i tell u lass time
- by Krow
