Old 25-08-2005, 03:27 AM   #1 (permalink)
Default My PC hangs after running 24 hrs. Why???
Well work loads made me keep my comps running more than 24 hrs. They have been hating me. Anywasy I have 2 comps running line by line.
1. P4@2.8 GHz HT / 865 GBF / 256 DDR / 80 GB Samsung / Win XP Pro
2. P4@2.4 GHz / 845 Mercury / 128 DDR / 80 GB Seagate / Win XP Pro
Now PC1 hangs after running more than 24 hrs while PC2 remains calm, works well. Applications start crashin' and there is nothin much i can do on it except switching it off. At the same time PC2 is cool works fine.
Last time i ran it continuously for 36 hrs, it simply restarted. And saying Recovered from serious error.
So what do i do? OS problem/ hard disk errors or what? I am puzzled. Waitin' for expert comments.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 25-08-2005, 07:50 AM   #2 (permalink)
Netjunkie's Avatar
Definetly a heat issue.
First try cleaning the cabinet & all the fans, make sure they are free from dust. Monitor the fan RPM & make sure they are working proprly.
Netjunkie is offline
Old 25-08-2005, 11:24 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
get some serious cooling man.... also might wana chech this thread... & hit a search as many thread is here about Hit issue....
help: - Installing Cabinet FAN....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-08-2005, 12:39 PM   #4 (permalink)
Posts: n/a
yes hitting may cause to pc to hang .. i also had similar prob at that time i simpling cut the side of cabinet and installed one fan there.. so it was solved
Old 25-08-2005, 12:49 PM   #5 (permalink)
allright, i c its a heat problem. i went to the link given above and it was really so helpful
well but i m really not able to decide to put da extra one in side or back, as when i put it in side it rili creates a big problem when u open the cabinet. have to detach the power cable each time
PriyaRanjan Singh
Old 25-08-2005, 08:25 PM   #6 (permalink)
Its a coomon heating issue with P4 HT . in fact i must say that u are lucky u can run the rig for 24hrs at a stretch .My firends cant even use for 2hrs at a stretch. Thats y amd 64 rulez.
Coming to the sol. use good thermal paste and a good cooling fan with copper core and a couple more system fans
cyrux is offline
Old 25-08-2005, 08:44 PM   #7 (permalink)
expertno.1's Avatar
hmm.if u r rich enough u should use water coolent systems
expertno.1 is offline
- by Krow
