Old 24-08-2005, 08:34 PM   #1 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default RAM BLUES !!!!!
hellooo folks !!!
i think i have a problem ....
i am running on 512 mb RAM ie (2*256);
i am using windows-xp sp2
my problem is with the amount of ram left unused , it is generally 220 mb
but all friends running on single chips of 512 mb get something like 350 mb unused ;
we have the same programs installed;
so what is the problem;
is it with the dual porting of the ram to get a faster system ;
or is there any prob with the ram chips
please tell me !!!!!!!!!
vijay_7287 is offline
Old 24-08-2005, 09:03 PM   #2 (permalink)
u must have some more services or programs or both running in the background than ur frnds, i think that can be the only cause.
Shwetanshu Srivastava
shwetanshu is offline
Old 01-10-2005, 12:52 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i think i have a better answer now
the problem was in the bios settings the agp aperture size was set to 256 mb
and the 16 mb was reserved for the agp so i was loosing about 100 mb of ram there so folks better be careful
Old 01-10-2005, 02:01 PM   #4 (permalink)
desertwind's Avatar
it means that the programs are using more RAM. thats really good. lot of unused RAM is a wastage. But the real problem arises when this ram is not shared when new programs are executed. Try opening a 10 programs simultaneously on both machine, and did u feel any difference ?
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
- by Krow
