Old 24-08-2005, 04:45 PM   #1 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Convert phpBB to vBulletin
I have made a forum using phpBB 2.0.17. I want to convert it to vBulletin 3.0.8? How do i do this? I already have vBulletin 3.0.8 with me.
navjotjsingh is offline
Old 24-08-2005, 05:30 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try this convertor :
ImpEx
found it on VB site...
cant acess it though
www.vbulletin.com/forum/showthread.php?t=150188
more info :
http://www.theadminzone.com/forums/a...hp/t-1678.html
http://www.vbwebmaster.com/forums/vb...php/356-1.html
srry, thought u can convert readin the about section of earlier link...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 24-08-2005, 05:35 PM   #3 (permalink)
I am Optimus Prime
EDITED: NO longer holds valid.
Old 24-08-2005, 06:38 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
how bout using this to post...
any way.. read them... i am not sure... but still thought of posting...
http://www.vbulletin.com/forum/showthread.php?t=116398
http://www.vbulletin.com/forum/showthread.php?t=148918
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 24-08-2005, 07:19 PM   #5 (permalink)
Version 2.0
Deep's Avatar
Default Re: Convert phpBB to vBulletin
in your vBulletin's member area you will see option called Impex...so just download the convertor from there and get the things rolling
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 24-08-2005, 09:16 PM   #6 (permalink)
I am Optimus Prime
Thanks a lot Deep again. I have converted successfully. It is not very easy to understand Impex at first but managed to do it successfully.
Thanks again Deep.
Old 24-08-2005, 09:52 PM   #7 (permalink)
Version 2.0
Deep's Avatar
welcome
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 25-08-2005, 03:55 PM   #8 (permalink)
I am Optimus Prime
Another query - How do I transfer any forum from my PC to a online webserver provided it supports MySQL and PHP? I know how to upload forum software but what about the forum database? My forum is hosted on my PC using EasyPHP.
Old 25-08-2005, 03:57 PM   #9 (permalink)
Version 2.0
Deep's Avatar
take backup of database, may be you can use PHPMyAdmin and export the tables in sql or gz file..
and then upload the same on your server using PHPMyAdmin
then change config file of your forums and provide details of current db and user...
That should do the job
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 25-08-2005, 06:40 PM   #10 (permalink)
I am Optimus Prime
I have exported a file with extension sql. In which folder do I upload and there is no import option in phpMyAdmin. I could not find the folder in which there should be a folder and a file related to an exisitng database.
BTW your reply was very quick. I noticed at that very moment but did not reply because at that time I was at net cafe and wanted to go home and check it for myself.
Old 25-08-2005, 11:40 PM   #11 (permalink)
sting's Avatar
is there any way to Convert phpBB to IPB ?
Visit my Daily Photo Blog at http://www.iamsarath.com
sting is offline
Old 26-08-2005, 09:39 AM   #12 (permalink)
I am Optimus Prime
Free Convertors to move from phpBB 2.0.6 or above to IPB 1.3 and IPB 2.0 are available at http://www.invisionpower.com/ip.dyna...onvertors.html
Old 26-08-2005, 09:51 AM   #13 (permalink)
Version 2.0
Deep's Avatar
Sorry couldnt reply quickly this time I somehow didnt get email notification....(it happens when somene deletes the post in this thread)
anyways back to the point...go to option called SQL there you will see a text box to enter the sql query and below that there will be option to upload sql file...
So upload it it handle the rest...
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
- by Krow
