Old 24-08-2005, 01:51 AM   #1 (permalink)
Default remote desktop urgent
when ever i connect my host to the sever through remote desktop in the work group the sever stops and displays the welcome screens of all the users but i need to work on both simutaneously ....plz let me kow the settings to be done if any .
zuhaib is offline
Old 24-08-2005, 02:41 PM   #2 (permalink)
Version 2.0
Deep's Avatar
actually server doesnt stop but it locks that user screen for the time being....the process on the server always runs..
anyways if you want both to be displayed then use software called VNC, it should be installed on both the sides..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 24-08-2005, 10:43 PM   #3 (permalink)
Default remote
is there any other inbuilt settings that can do this work on bothsides of the systems
zuhaib is offline
Old 24-08-2005, 11:05 PM   #4 (permalink)
What exactly do you mean by "both sides of the system"
Do you mean to say controlling both simultenously at the same time?
www.Oobertech.net
digen is offline
Old 24-08-2005, 11:12 PM   #5 (permalink)
yes
zuhaib is offline
Old 24-08-2005, 11:22 PM   #6 (permalink)
Errm afaik that isnt possible with a software such as VNC [by VNC i mean all those remote client/server apps such as Tight VNC,UltraVNC to name a few].
Forgive me for asking this but what is your requirement may I ask?
Controlling both the systems even with reverting roles will involve making use of their mouse movements plus anything that is being carried out on the system.
www.Oobertech.net
digen is offline
Old 24-08-2005, 11:50 PM   #7 (permalink)
Default remote destop
i want to use my two systems simutaneously with each doig its own task seperately.
i used the VNC but it shows the same program on both the computers and i dont want that.i want hem to work seperately using remote desktop connection .plz help me
zuhaib is offline
Old 25-08-2005, 03:14 AM   #8 (permalink)
o diggy wat hew means that when he RDC's the server goes on logon screen instead of showing desktop
and vnc shows the program he is runnin
boss thats bound to happen..
u can run programs on the server directly ...bu it WILL display the work u r doing remotely .. that is but obvious.. no matter wat software u use
No Mercy, No Limits.
theraven is offline
- by Krow
