| Forum |
#1 (permalink) |
my exams going so a short post only my dad agreed 4 a new comp after exams i.e. 29th the approx cost dad says must be below 30-35k plz help me get a good config i am a GOOD GAMER so hers it 512 mb ram? is it ok or more? 40gb hard disk dvd writer intel p4 processor plz help me choose more |
#2 (permalink) |
Hmmm...I think this would be a good option:-
AMD Athlon 64 3200+ MSI RS480M2-IL Mobo 512 MB DDR RAM (1GB would do better) Samsung 80GB-7200rpm HDD Sony DRU710 DVD Writer and other "normal" things. All this, you can get under 35k. Onboard ATi chipset is pretty good! You can refer July Digit for this motherboard test/review. [Edit]Plz move this to Hardware section.
http://swatrant.blogspot.com/ |
#3 (permalink) |
Posts: n/a
better & possible option in your budget
AMD Athlon 64 3000+, venice core, or 3200+, but venice core Gigabyte GA-K8NXP-9 motherboard or ASUS A8N-E 2X256 MB DDR400 Samsung 80 GB SATA Lite-On or Sony DVD writter Gainward or XFX GeFource 6600GT, as there is no onboard video in this motherboard |
#5 (permalink) | |
Manchester United
A64 3000+ ~ 7500 A8N-E ~ 6500 XFX 6600GT PCI-ex 128MB DDR3 ~ 10500 Yes, get a GB RAM if possible but even if you settle for 512MB get a 400MHz RAM. Lower freq are no good. And stay away from the MSI board. It is more expensive but not better than the Asus board. That one is based on the nforce4 ultra chipset and the best available in the market. And don't get a DVD-writer unless it's absolutely necessary. Get a combo drive instead. It is cheaper and also a good value for money. Get a 80GB HDD as well. You decide the rest of the components but these are must. Thanks
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen
#6 (permalink) |
Manchester United
Sorry about the MSI board. I mistook it for the Neo 4 platinum. That was much more expensive. This board is good and is cheaper and also has onboard ATI graphics and a PCI-ex slot and onboard LAN and sound. It is also around 1500 bucks cheaper than the A8N-E. Get this if your budget falls short otherwise get the A8N-E.
#8 (permalink) |
Resident Weapons Expert
Tell that sales manager that he is better of selling the stuff rather than advising on technical issues (which he doesnt know anything about) and also remind him to grab a copy of Digit if he wants to upgrade himself to 21st century rather than 18th century.
Stalk, Strike, Survive. |
#10 (permalink) |
Posts: n/a
i third Zombie, that sales manager is simply saying that to eat his commision
AMD Athlon 64 3000+ will give u performance equivalent to a Pentium 4 3 GHz when installed on a 915G motherboard, but it will also run a lot cool in temprature if Intel, then go for Pentium 4 6xx series, 2.8 GHz is enough, Intel 915GAG or any other 915G motherboard, U will get FX 5200 level graphics which u can lator upgrade |
#11 (permalink) |
Crux of the matter is Intel CPU/mobo combo will be costly if you do a cost/benefit analysis. So go for AMD. After all so many AMD fans cant be wrong. I dont say that Intel is bad. Just that for the same amount you can get much more with AMD.
#12 (permalink) | |
Most probably they are just not familier with amd....most of the assenmblers are trained on intel platform so they just dont want to go with amd in fear of something unexpected. Another coz may be.....that intel costs more so the profit margin is greater Any way thake a goos decision...trust experts niot nerds like ur ****** manager
Bombina rocks |
#13 (permalink) |
When we went to purchase a PC for my room mate in Jan 2002, word on the street was that AMD CPU heats up a lot. Still we went for AMD, our simple arguement was that if you use AMD recommended heat sink, there wont be any problems. Without proper heat sink even mighty P4 may conk off.
#14 (permalink) |
take it from me ---P4 has heating probs while amd 64 doesnt have....ask for ur sales manager on what bechmarks is he advising u intel and i m sure he will go mum.....i tell u its because of such people intel is still so popular
#15 (permalink) | |
#16 (permalink) | ||
Manchester United
#17 (permalink) |
Today if you think about 64-bit computing, of course if you think the future is 64 - at least I think so, the winner is AMD. In this forum you would find several topics by me on AMD64 and 64-bit computing.
Config.: AMD Athlon 64 3200+ Socket 939 MSI RS480M2 Mainboard Kingstone 512 MB 400 MHz DDR RAM (Recommended 256 x2) Samsung 120 GB SATA-II HDD Sony DRU810A Microsoft Mouse-Keyboard combo, Others.
Orkut members are invited to join: http://www.orkut.com/Community.aspx?cmm=28705185 |
#18 (permalink) | |
I had a similar experience recently. I told a non techie friend to buy a 3000+ and a RS480 mobo. But the dealer flat out refused to build a AMD rig and said that he won't provide any warranty and won't repair it if anything goes wrong. His reason was that AMD runs really hot and has very poor performance. Yeah right! My system temp is 37 degrees WITHOUT any case fans. Lets see a Prescott top that. |
#19 (permalink) | |
#20 (permalink) |
well thanx a lot 4 ur replies
but my dad now says that budget must be less than 25k including ups. if possible dvd writer also. ive shown this page 2 my dad and 2morrow will show to my manager also well my dad also suggests if plz the digit's tec section can advice me on it im a class 9th student and a GAMER + i want to pursue my carrier as a soft engg. (most probably 3d designer designing game agrrrrrr MAYA!!!!!) |
#21 (permalink) |
then amd 2800+,msi rs 480,512 ddr 400,6200 128 mb,80 gb sata,17" non flat,dvd writer ,ups,basic logitech optical mouse nd kbd,basic altec lansing stereo spk...this is the best u can get @ 25k
Bombina rocks |
#22 (permalink) |
Whether you budget is 20k or 50k please go for a AMD processor.. This Heating issue is crap.. You can trust all these people in the forum here.. Dont think twice go for AMD..
I hope your DAD reads this.. Sir, better invest around 35k on the PC and buy a 939 Pin Based Processor.. It is Future Proof.. 25k on a new PC especially for gaming is a bit too less.. Thats just my honest opinion..
Top 10 |
| Bookmarks |
| Display Modes | |
