23-08-2005, 06:06 PM
please help in java program
Problem 4
DO NOT USE ANY LOOPS,IF ELSE OR SWITCH CASE
Write a program that transforms numbers 1, 2, 3, 4, ....12 into the corresponding month names January, .........
For example, input is 5
Output is as follows:
Month name corresponding to 5 is May.
You will be writing a class MonthNames with a method for returning month name and any other thing required.
You also need to write a class TestMonthNames for taking input from user, creating object, calling methods and for output as shown above.
PLEASE CAN YOU GIVE CONCEPT OF HOW TO SOLVE ABOVE PROB
23-08-2005, 07:32 PM
string GetMonth(int idx)
string months[]={"January", "february","march","april","may","june","july","august","september","october","november","december"};
return (months[idx]);
Put this in a class, format the output and submit the assignment.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
23-08-2005, 07:38 PM
NO ARRAY IS ALLOWED
23-08-2005, 08:30 PM
Originally Posted by shivi4
NO ARRAY IS ALLOWED
You never said arrays were not allowed. Anyway, there must be some variation of calendar class u can use.
23-08-2005, 08:43 PM
import java.text.DateFormatSymbols
return (getMonths()[idx]);
It's more like a logic than actual code. See if that works.
23-08-2005, 09:39 PM
WE HAVE TO USE SIMPLE LOGIC
NO EXTERNAL CLASSES NO ARRAYS NO LOOPS IF/ELSE
NO SWITCH OR BREAK
ONLY CLASSES AND OBJECT S AND CONSTRUCTOR
DEFAULT DATA TYPE
24-08-2005, 04:46 PM
Commander in Chief
This one shows a lot of output but the correct one is a complete word...
import java.io.*;
class Month
public static void main(String args[]) throws IOException
String A;
DataInputStream in = new DataInputStream(System.in);
A=in.readLine();
System.out.println(A.replaceAll("1","January"));
System.out.println(A.replaceAll("2","February"));
System.out.println(A.replaceAll("3","March"));
System.out.println(A.replaceAll("4","April"));
System.out.println(A.replaceAll("5","May"));
// And So on....
Harsh J
www.harshj.com
24-08-2005, 06:20 PM
we have to use only string class and its method
24-08-2005, 06:24 PM
Commander in Chief
I dont get u ?
U mean i must not use replaceAll ?
Wat is string class and thier methods ?
Harsh J
www.harshj.com
24-08-2005, 06:53 PM
NO ARRAY IS ALLOWED
we have in built string class in java
we have to its method only like indexof,substring etc
24-08-2005, 06:56 PM
Well, he did use string clas and its methods. The datainputstream was only to get a kbd input. U can replace it with a function argument input.
Search this Thread |
