23-08-2005, 05:52 PM
Mobile Freak
SPEED or SECURITY
I install 'Zone Alarm Pro 5.5' in my PC n using BSNL 'NetOne' as my ISP for surfing! The problem is that when d FireWall is turned on,my browsing speed becomes so slow.But whn I turned it off,my net speed boosts up high.In this case i have 2 choose one thing,SPEED or SECURITY...but i wana both of them.Because internet is full of threats!Plz tell me how 2 gain high speed not 2 turning Firewall off?I have 'WinXP SP1' as my OS.
Hope 4 d best n Do d right :)
23-08-2005, 07:15 PM
Commander in Chief
Install SP2 for ur XP , it comes with a good firewall, basic but good enough...
Also, Zone is light, but wats ur sys config ?
Also, Speed vs. Security has always been a never ending debate...
Harsh J
www.harshj.com
23-08-2005, 08:24 PM
Distinguished Member
dunno........i have installed zass and while on the net, dont experience a drop in speed....... basic config is what i have; inclu 256mb ram.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
23-08-2005, 08:47 PM
well i too recently installed zap 5.5 few days back but no issues here.
23-08-2005, 08:54 PM
theres no any problem in that i am not sevn using any firewall in that
is there any harm in not using firewall ?
23-08-2005, 08:56 PM
Windows Firewall does the JOB well.
\" I Do not like to repeat success , i like to move on to other things \"
23-08-2005, 09:15 PM
@expertno.1
Lot of problems will happen if you donot use firewall.......
23-08-2005, 09:41 PM
Just Do It
Re: SPEED or SECURITY
For trusted sites u can disable it and for the others use it even if its slow.
BTW thats a weird prob. Ive been using without any hassles.
23-08-2005, 09:53 PM
Commander in Chief
looks like many spieswares are residing on his comp and zap is busy defending em all...
Post an hijack this log and also see the amount of process zap takes when conneced to the net...usig the Task Manager of course...
Harsh J
www.harshj.com
23-08-2005, 09:54 PM
well my speed did drop but initially i think give it some time it will put the sites that u regularly visit into secured zone .
and yes a weird problem.
i wud prefer za to windows sp2 firewall as it is more configurable.period.
and can u test ur speeds with www.zdnetindia.com and post ur results with firewall on and off?
"Try again, fail again, fail better" - Samuel Beckett
23-08-2005, 11:55 PM
I totally agree to it. Yes windows Xp SP2 firewall is good enough
23-08-2005, 11:58 PM
24-08-2005, 01:55 PM
Mobile Freak
Is their is no way 2 skip SP2 installation 2 gain good speed?Did u heared abt any other Firewall software which is light than ZoneAlarm and can do good job while surfing :roll:
24-08-2005, 02:06 PM
Just Do It
I suggest u go for Tiny Firewall....
U cud try these also...
Black Ice Defender
Mcafee Personal Firewall
Sygate
24-08-2005, 07:57 PM
@reddick
You can use Sygate as it is very light in system resources...... I my self use it...
25-08-2005, 05:53 AM
Mobile Freak
Frm where can i gt it 4 FREE  Is it can b compared 2 ZoneAlarm in features
25-08-2005, 01:05 PM
Just Do It
Google search it....
25-08-2005, 02:21 PM
windows firewall sux ..
its not for novice users ..
usage of security software depends largely on ur own knowledge ..
and windows firewall is not for any novice ..
it cant protect ur system from jack **** ..
its the most vulnerable firewall out there ... im ashamed to even call it a firewall ..
there is something really wrong with ur system. .. cuz a firewall can NEVER slow down ur net speed.
im using zone alarm and there is no way its slowed my net speed in any way ... except it uses a lil bandwidth to check for program updates .. which ofcourse u can turn off ...
i cant figure ur problem ... but zap is one of the best out there .. try shuttin the autoupdate feature and see if it makes a difference ..
anyways whats the speed of ur connection ?
No Mercy, No Limits.
25-08-2005, 03:29 PM
#19 (permalink)
1. Personally, I won't recommend using both the Win Firewall and a third-party firewall together. Turn off the Win Firewall of and use only ZA.
2. Check the logs of your firewall. Too much activity shows the signs of spyware activity. Do a thruogh spyware scan to be sure.
Don\'t SYN me, I'll SYN you. :p
25-08-2005, 04:13 PM
#20 (permalink)
Mobile Freak
I'm using internal modem n d speed is 33kbps approx. I scan whole my system 4 spyware n aidwares but found nothing...I defrag my HDD regularly too...This speed suxs...i gona FU*K BSNL
25-08-2005, 04:17 PM
#21 (permalink)
thats the problem..
33kbps. . not za ..
the boost is probably cuz of the automatic updates ...
just try shuttin it off ...
26-08-2005, 04:20 PM
#22 (permalink)
Mobile Freak
I have disabled it...No gains yet...Still i have 2 shut off d firewall while surfing  Than i have to scan whole my PC 4 viruses everytime after browsing
26-08-2005, 04:36 PM
#23 (permalink)
yaar ek kaam kar
post ur hijack this logfile here once .. so we have that out of the way
26-08-2005, 04:54 PM
#24 (permalink)
Mobile Freak
Wht is "hijack this logfile"? I'm newbie to computing...plz tell me in brief
27-08-2005, 12:32 AM
#25 (permalink)
ok sorry my bad ...
here download the hijackthis program from here
then run it and copy paste the log file it creates here
27-08-2005, 06:40 AM
#26 (permalink)
Mobile Freak
Here is the log file:
Logfile of HijackThis v1.99.1
Scan saved at 6:34:02 AM, on 01-Aug-05
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
C:\WINDOWS\system32\cisvc.exe
C:\WINDOWS\System32\nvsvc32.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\System32\NVATray.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgemc.exe
C:\Program Files\Nokia\Nokia PC Suite 6\LaunchApplication.exe
C:\Program Files\Common Files\PCSuite\DataLayer\DataLayer.exe
C:\Program Files\Java\jre1.5.0_03\bin\jusched.exe
C:\Program Files\Logitech\iTouch\iTouch.exe
C:\PROGRA~1\Logitech\MOUSEW~1\SYSTEM\EM_EXEC.EXE
C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe
C:\Program Files\PowerMenu\PowerMenu.exe
C:\PROGRA~1\COMMON~1\PCSuite\Services\SERVIC~1.EXE
C:\PROGRA~1\COMMON~1\Nokia\MPAPI\MPAPI3s.exe
C:\Program Files\Opera\Opera.exe
C:\WINDOWS\system32\cidaemon.exe
C:\WINDOWS\system32\ntvdm.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\PROGRA~1\WINZIP\winzip32.exe
C:\Documents and Settings\Rana\Local Settings\Temp\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://netonejld.bsnl.co.in/
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\WINDOWS\SYSTEM\blank.htm
O1 - Hosts: 205.209.153.86 lloydstsb.co.uk
O1 - Hosts: 205.209.153.86 online.lloydstsb.co.uk
O1 - Hosts: 205.209.153.86 www.lloydstsb.co.uk
O1 - Hosts: 205.209.153.86 www.lloydstsb.com
O1 - Hosts: 205.209.153.86 personal.barclays.co.uk
O1 - Hosts: 205.209.153.86 barclays.co.uk
O1 - Hosts: 205.209.153.86 ibank.barclays.co.uk
O1 - Hosts: 205.209.153.86 www.barclays.co.uk
O1 - Hosts: 205.209.153.86 www.nwolb.com
O1 - Hosts: 205.209.153.86 nwolb.com
O1 - Hosts: 205.209.153.86 hsbc.co.uk
O1 - Hosts: 205.209.153.86 www.hsbc.co.uk
O1 - Hosts: 205.209.153.86 abbey.com
O1 - Hosts: 205.209.153.86 www.abbey.com
O1 - Hosts: 205.209.153.86 www.abbey.co.uk
O1 - Hosts: 205.209.153.86 abbey.co.uk
O1 - Hosts: 205.209.153.86 cahoot.com
O1 - Hosts: 205.209.153.86 www.cahoot.com
O1 - Hosts: 205.209.153.86 www.cahoot.co.uk
O1 - Hosts: 205.209.153.86 cahoot.co.uk
O1 - Hosts: 205.209.153.86 www.co-operativebank.co.uk
O1 - Hosts: 205.209.153.86 co-operativebank.co.uk
O1 - Hosts: 205.209.153.86 www.co-operativebank.com
O1 - Hosts: 205.209.153.86 co-operativebank.com
O1 - Hosts: 205.209.153.86 welcome2.co-operativebankonline.co.uk
O1 - Hosts: 205.209.153.86 welcome6.co-operativebankonline.co.uk
O1 - Hosts: 205.209.153.86 welcome8.co-operativebankonline.co.uk
O1 - Hosts: 205.209.153.86 welcome10.co-operativebankonline.co.uk
O1 - Hosts: 205.209.153.86 www.smile.co.uk
O1 - Hosts: 205.209.153.86 smile.co.uk
O1 - Hosts: 205.209.153.86 www.cajamar.es
O1 - Hosts: 205.209.153.86 cajamar.es
O1 - Hosts: 205.209.153.86 www.cajamar.com
O1 - Hosts: 205.209.153.86 www.unicaja.es
O1 - Hosts: 205.209.153.86 unicaja.es
O1 - Hosts: 205.209.153.86 www.unicaja.com
O1 - Hosts: 205.209.153.86 unicaja.com
O1 - Hosts: 205.209.153.86 www.caixagalicia.es
O1 - Hosts: 205.209.153.86 caixagalicia.es
O1 - Hosts: 205.209.153.86 www.caixagalicia.com
O1 - Hosts: 205.209.153.86 caixagalicia.com
O1 - Hosts: 205.209.153.86 activa.caixagalicia.es
O1 - Hosts: 205.209.153.86 www.caixapenedes.es
O1 - Hosts: 205.209.153.86 caixapenedes.es
O1 - Hosts: 205.209.153.86 www.caixapenedes.com
O1 - Hosts: 205.209.153.86 caixapenedes.com
O1 - Hosts: 205.209.153.86 bancae.caixapenedes.com
O1 - Hosts: 205.209.153.86 www.caixasabadell.es
O1 - Hosts: 205.209.153.86 caixasabadell.es
O1 - Hosts: 205.209.153.86 www.caixasabadell.net
O1 - Hosts: 205.209.153.86 caixasabadell.net
O1 - Hosts: 205.209.153.86 www.cajamadrid.es
O1 - Hosts: 205.209.153.86 cajamadrid.es
O1 - Hosts: 205.209.153.86 www.cajamadrid.com
O1 - Hosts: 205.209.153.86 cajamadrid.com
O1 - Hosts: 205.209.153.86 oi.cajamadrid.es
O1 - Hosts: 205.209.153.86 www.ccm.es
O1 - Hosts: 205.209.153.86 ccm.es
O1 - Hosts: 205.209.153.86 www.haspa.de
O1 - Hosts: 205.209.153.86 haspa.de
O1 - Hosts: 205.209.153.86 ssl2.haspa.de
O1 - Hosts: 205.209.153.86 www.dresdner-bank.de
O1 - Hosts: 205.209.153.86 dresdner-bank.de
O1 - Hosts: 205.209.153.86 www.dresdner-privat.de
O1 - Hosts: 205.209.153.86 postbank.de
O1 - Hosts: 205.209.153.86 www.postbank.de
O1 - Hosts: 205.209.153.86 banking.postbank.de
O1 - Hosts: 205.209.153.86 www.sparda-b.de
O1 - Hosts: 205.209.153.86 sparda-b.de
O1 - Hosts: 205.209.153.86 www.bankingonline.de
O1 - Hosts: 205.209.153.86 www.raiffeisenbank-erding.de
O1 - Hosts: 205.209.153.86 raiffeisenbank-erding.de
O1 - Hosts: 205.209.153.86 www.vr-networld-ebanking.de
O1 - Hosts: 205.209.153.86 vr-networld-ebanking.de
O1 - Hosts: 205.209.153.86 www.bnhof.de
O1 - Hosts: 205.209.153.86 bnhof.de
O1 - Hosts: 205.209.153.86 www.deutsche-bank.de
O1 - Hosts: 205.209.153.86 deutsche-bank.de
O1 - Hosts: 205.209.153.86 meine.deutsche-bank.de
O1 - Hosts: 205.209.153.86 www.citibank.de
O1 - Hosts: 205.209.153.86 citibank.de
O1 - Hosts: 205.209.153.86 cipehb13.cdg.citibank.de
O1 - Hosts: 205.209.153.86 www.dkb.de
O1 - Hosts: 205.209.153.86 dkb.de
O1 - Hosts: 205.209.153.86 www.sparkasse-regensburg.de
O1 - Hosts: 205.209.153.86 sparkasse-regensburg.de
O1 - Hosts: 205.209.153.86 www.berliner-bank.de
O1 - Hosts: 205.209.153.86 berliner-bank.de
O1 - Hosts: 205.209.153.86 www.berliner-sparkasse.de
O1 - Hosts: 205.209.153.86 berliner-sparkasse.de
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
O2 - BHO: (no name) - {206E52E0-D52E-11D4-AD54-0000E86C26F6} - C:\PROGRA~1\FRESHD~1\FRESHD~1\fdcatch.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [SystemTray] SysTray.Exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE NvQTwk,NvCplDaemon initialize
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NVIDIA nForce APU1 Utilities] NVATray.exe
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [AVG7_EMC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgemc.exe
O4 - HKLM\..\Run: [Zone Labs Client] C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
O4 - HKLM\..\Run: [PCSuiteTrayApplication] C:\Program Files\Nokia\Nokia PC Suite 6\LaunchApplication.exe -onlytray
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKCU\..\Run: [PcSync] C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe /NoDialog
O8 - Extra context menu item: &Google Search - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsearch.html
O8 - Extra context menu item: &Translate English Word - res://C:\Program Files\Google\GoogleToolbar1.dll/cmwordtrans.html
O8 - Extra context menu item: Backward Links - res://C:\Program Files\Google\GoogleToolbar1.dll/cmbacklinks.html
O8 - Extra context menu item: Cached Snapshot of Page - res://C:\Program Files\Google\GoogleToolbar1.dll/cmcache.html
O8 - Extra context menu item: Similar Pages - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsimilar.html
O8 - Extra context menu item: Translate Page into English - res://C:\Program Files\Google\GoogleToolbar1.dll/cmtrans.html
O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O16 - DPF: Win32 Classes -
O17 - HKLM\System\CCS\Services\Tcpip\..\{6125F156-0689-4F08-B97F-559E512CA7BB}: NameServer = 61.0.64.33 61.0.0.5
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs, LLC - C:\WINDOWS\SYSTEM32\ZONELABS\vsmon.exe
Now tell me where is d problem n how to resolve it...cheers bro!!!
27-08-2005, 07:19 AM
#27 (permalink)
hey is it necessay to use firewall coz i dont use anyone ?
28-08-2005, 06:58 AM
#28 (permalink)
Mobile Freak
28-08-2005, 07:01 AM
#29 (permalink)
Mobile Freak
Yeah it so imp. 2 install it in ur PC...As internet is flodded with various types of viruses,worms n hackers...They can infect ur machine...It's better 2 install firewall n it's a must so that u remain safe n secure...u can gt it free in DIGIT CDs
28-08-2005, 07:07 PM
#30 (permalink)
Thats a pretty interesting thread but I have one simple straight forward solution.
Sacrificing safety for speed will lead you to the dumps !
I hope you get the point.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
Search this Thread |
