Sometimes yes, specially when you deny some directories which you do not want other ppl to see...
for example...
u have denied directory name admin
so google wont scan but hacker or anything will check robots.txt and see what is denied and then try to play with it...
so if you are denying any directory then password protect that directory using .htaccess rule so that no one can play with it much..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
